Old 05-02-2015, 09:22 AM   #1
HONDAMAN174's Avatar
Class A charging question
Helping a friend install a small inverter for powering the TV/DVD player while they are driving for the kids. Does the alternator charge the house batteries while driving or just the chassis battery?
When in doubt...ask!
Just glad to get away
Old 05-03-2015, 10:07 AM   #2
Bump
Old 05-03-2015, 11:19 AM   #3
RPAspey's Avatar
It should. If I'm not mistaken, there should be a relay called "BIRD" Bi-directional Isolation Relay Delay. You could check to see if your buddy has one in his coach.
Or
You could put a multimeter on the house battery and measure the voltage with shore power disconnected. Start the engine and watch for the voltage to increase to about 14v. If it does, the engine is charging the batteries.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 05-03-2015, 03:05 PM   #4
Ok. That I can do. Thanks for the direction.
Old 05-04-2015, 04:07 PM   #5
Our Sportscoach does, verified by voltage and amperage.
rzrnaz is offline   Reply With Quote
charging
