Old 07-10-2012, 07:29 PM   #1
Paul & Sheri
pwb01's Avatar
Cleaning aid
I bought an inexpensive kitchen sink sprayer and cut in a Sharkbite Tee fitting with the adaptor for the sprayer in the water line behind the toilet. I mounted a camper showerhead holder on the wall along side the toilet to hold the sprayer.
You can buy these without the plumbing tee at Campers World for $65 for toilets with the fittings already there and mine installs on any water line and cost $25 total with the Sharkbite tee being half the cost. Installation took less than 10 minutes. (half that time carefully cutting the plastic pipe with a pipe cutter)
Additionally, with Sharkbite fittings I installed a 2 gal accumulator tank in 10 minutes which saves the pump and battery (minimizing high amp starts) and provides smooth flow.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 07-11-2012, 01:01 PM   #2
Herk7769's Avatar
Awesome! Great Job!
The hand held wand is a big deal when boondocking as cleanup now takes a fraction of the water it previously did and we use the wand to pre-fill the bowl when needed (instead of using the flush lever - if you press too hard the bottom valve opens and you have to start over again).
See http://www.forestriverforums.com/for...c-v-15261.html
For how I did it. I also used a T fitting so I did not need to flush to use the wand. I just added a valve in the wand handle in order to use shut it off when we travel. I was afraid it would fall and potentially discharge.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 07-13-2012, 09:13 PM   #3
Paul & Sheri
pwb01's Avatar
I like the idea of the shutoff. I never leave the pump on while moving but I do have a 2 gal accumulator tank so I could discharge close to 2 gal without the pump on.
2006 Sunline T1950
2004 T@B T-16
Old 07-23-2012, 08:32 PM   #4
Freds342's Avatar
My Sealand toilet is close enough to the tub/shower that I don't need an additional sprayer.
I learned that when I bought an Aqua-Magic 4 for my Wildwood 32'. The sprayer was redundant. Already had a shower head right next to the loo.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
