Old 08-31-2016, 02:33 PM   #1
ronzo101's Avatar
Closet Slide Door mod on Flagstaff 27RLWS
In our Flagstaff 27RLWS closet slide with 2 sets of doors in the bedroom, it was useless to try to gain access to the forward part of the closet due to the way the forward set of doors opened and the proximity of the bed.
One door opened into you and you had reach around the door or get on the bed to gain access to that forward section.
I ended up taking both doors off the forward set, installed a piano hinge were both doors previously met when closed, reinstalled the now one set of bi-fold doors using the forward hinges only (plus added 2 more identical hinges on that side for the added weight) making the forward set of doors a bi-fold that folds forward allowing easy access to that end of the closet slide.
(FYI: I used existing hinges that I found on cabinet doors that were not suppose to open....in our unit they hinged those doors and used a hinge on the bottom to prevent accidental opening. Now have installed catches for those.)
I left the knobs and catches in the same position as well as the aft set of hinges on the frame opening.
Now when you close the bi-fold door, it butts up to the aft hinges that are left unused on the frame on the opening side and latch in the middle where the existing catches are. Just push the middle of the doors to secure to the catches or pull one of the 2 knobs to open the doors.
Plus you can't tell it's a bi-fold until you go to open it thus it matches the other doors in that slide
Works great and so far nothing has opened while travelling............just an idea that worked for us...
ronzo101 is offline   Reply With Quote
Old 08-31-2016, 02:39 PM   #2
It is still only an 'idea' unless you post pictures.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 08-31-2016, 04:56 PM   #3
ronzo101's Avatar
Well....all I can say is pictures will follow this weekend....thought was on my mind to post it when I had the time & the place........you won't be disappointed...
Old 08-31-2016, 05:03 PM   #4
Canadiancrew's Avatar
Yes someone posted a pic elsewhere in this forum. Looks great I may consider this myself. I thing I even have a piano hinge already.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 09-04-2016, 09:50 PM   #5
ronzo101's Avatar
Closet Slide Door mod on Flagstaff 27RLWS Pics
Here's some pictures of my modification to the closet slide that I should have shown when I first posted the thread:
1st shows it closed and matches as it was designed.... the head of the bed is to the right.
The closet door shown to the left is accessible as designed because the foot of the bed ends with enough room to open and gain access.
2nd shows it bi-folded as well as the original hinges still in place on the face of the frame.
And last, the placement of the piano hinge as well as the 2 added hinges for strength. There is one hinge at the bottom that is out of view.
Again, as I stated in my original thread, catches were left in they're original positions and latch securely.
ID:	119408   Click image for larger version
ID:	119409   Click image for larger version
Old 09-06-2016, 04:11 PM   #6
Thanks Ronzo,,, You just gave me more work to do LOL. DW loved the idea and
wants it done asap..
2015 Flagstaff 27RLWS
2014 Ram 2500 4x4
Softball Nut is offline   Reply With Quote
Old 09-06-2016, 06:11 PM   #7
pt1655's Avatar
hidee ho
Great post and great mod! I know this will help others with the same problem. Most of us rv'ers are pretty good with tools and doing mods.
Happy Camping!!
2013 Forest River Surveyor SP220 Sport
2012 Ram 1500 4X4, 5.7L Hemi quad cab, Bullydog GT tuner, true dual exhaust, 85mm throttle body, AFE dry filter
pt1655 is offline   Reply With Quote
door, flagstaff, slide, modifications
