Old 06-01-2013, 05:35 AM   #1
crunchman12001's Avatar
Coachman screen door MOD
We did not like the OEM screen door, slide door. The little door always was left open because you had to slide it open to unlatch the screen or to close the door when connected to the main door. I installed the Lippert Components, Inc - Slider; Screen; Towable W/Knob #239061 & Camco 42183 RV Screen Door Cross Bar . The door panel now has a disc you push down to open screen door. The cross bar is really nice to pull the doors closed.
Name:	Interior - OEM screen door slide door - Before.jpg
ID:	31892   Click image for larger version
ID:	31893   Click image for larger version
ID:	31894   Click image for larger version
Name:	Lippert Components, Inc - Slider; Screen; Towable WKnob #239061 & Camco 42183 RV Screen Door Cro.jpg
ID:	31895   Click image for larger version
2015 F-250 FX4
Old 06-01-2013, 05:45 AM   #2
please delete post, double pics- sorry
2015 F-250 FX4
Old 06-01-2013, 06:47 AM   #3
Our 12Flagstaff8528RKWS came with that center and I added a bar that we push and it unlatches the latch. Works good and is handy.
Name:	Bar with spring.jpg
ID:	31898   Click image for larger version
Name:	Latch Mechanism.jpg
Old 06-01-2013, 08:03 AM   #4
Our Sabre came with that disc type opener. Works great. On our previous Jayco TT I installed one of these: Screen Door Opener - Camco RV 43953 - Screen Doors - Camping World
Old 06-01-2013, 08:40 AM   #5
We had the Camco openers on our Outback that I had installed. They worked good but the disc type are much better. Cheap too @ $16.00 / each
2015 F-250 FX4
Old 06-01-2013, 08:46 PM   #6
PHS79's Avatar
I tried to get one of these slider panels to install into our 2012 Grey Wolf, after seeing a friends 2012 Grey Wolf with the disc. I took measurements of each and found that ours is 12X12 and our friends was roughly 9 3/4X12. I called Lippert to order the slider panel with disk for ours and found out that they don't make a 12X12 panel with the disc, only the smaller one, but Lippert said that they could build me a screen door with the smaller panel so I could get the disc...
I then did some more research and found out that our 2012 TT is an early production 2012 and our friends 2012 is a later production, and Lippert changed the screen doors used in the Grey Wolf TTs about 1/2 way through the year.
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 06-01-2013, 09:09 PM   #7
Buy the small panel, remove the disc, mod your panel and install the disc in your existing panel and you have what you want.
Old 06-01-2013, 09:16 PM   #8
PHS79's Avatar
I thought about that and almost order the small panel, but I want to look at one on our friends camper before I ordered it. Just to see how everything is put together and make sure that I can get it apart without breaking it.
The other option is for OC to go into the screen door push bar opener business like you did with the poles, then just buy from you again!
nights camped:
