09-03-2011, 04:39 PM
coax jack
I need to add a cable tv jack on the outside of my camper . I can easily wire to the spot on the interior of the camper to the entertainment center. Any imput on what to use to get to the exterior would be appreciated.
Rich + Lori -2006 salem 27BHSS/2004 Avalanche
4:10 rearend - Roxy the puppy when allowed.
41 Days camped in 2011 and counting.
09-03-2011, 06:28 PM
The DW would not let me drill a hole in the wall...so I bought a splitter and another piece of coax and when the weather is cool enough we bring the tv out of the bedroom and set it up on a table outside with the new coax.
2011 FORD F350 CREW CAB DUALLY DIESEL
2010 Salem LA 292FKDS
NIGHTS CAMPED IN 2010...33...IN 2011...67....IN 2012.....7 SO FAR.
LOOKING FORWARD TO FROG GOSHEN IN AUGUST 2012
FROG MEMBER
09-03-2011, 07:07 PM
RV Newbie
Two options I can think of. They make a flat section of coax cable that you can pass out a window or door and close them on it.
Or you can drop down thru the wall and out thru the floor, maybe use an existing wire to lead the way. Not sure what model you have but I easily ran a coax cable out while I worked on the overhead cabinets on my Lexington. I did not add a wall mounted jack, I just ties off about 10 feet of cable in a lower compartment. That way a have a direct cable from second set port on the back of the amplified jack inside.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
09-03-2011, 08:29 PM
I like the flat coax idea --seems easy and not too intrusive.
09-04-2011, 09:27 AM
flat coax
I just ordered two flat cables on Amazon for $.01.. and $4.99 shipping.
How can you go wrong?
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 531 |
| 96 members and 435 guests |
| 4bnabird, Adony, Al Fresco, amxpress, Big Vic, Biscuit, blaisrv, bowshark, bozemancamper, Buffalohunter, campnqueen, Canuck_Doug, Char_n_Kath, cousin01, dashonthedash, daveinpickerington, davidjb, daw592, DonG, donn, duchie, Elidh, f1100turbo, firedaniel, freedom 750, fx4roo, gandr96, Gary0848, gimp425, Gman88, gucci, herk7769, heytomgraywolf, Hob, honda1, hoovercab, Iggy, jacksum2, Jeep4Two, JJFerg, Joseph5410, kathomas, kb4srn, ken0042, KKapa, KRS, Lumpty, mack63, Mad4sax, maggiek, mamentt, manvel, mike1329, milw156, mraynie, mtl roofer, NanaKaren, NeilM108, newby, NO3putt, NorminN.B., okdrifter, papap, polkatronron, PrairieBoy, railstar, rburk015, rickthelen, RickV, RJHuser, rkswyo, RV Guy, Sahgie, Saratoga Camper, Sawdr73, sherdep, sideout1961, softwarejoe, sprayking, spurge1947, stevem4134, thewren, Tincup13, Titleguy, Top B, TopGobbler, troyt, ugeesta, venturetaz, Vette4trcr, wbdvt, Whiteknight, will4u, wnytaxman, wvfireboss, yworrydog |
| Most users ever online was 1,025, Today at 01:04 PM. |
