Old 07-15-2016, 11:05 AM   #1
Collapsible Directv Slimline Dish
Well, I wanted to make it a folding dish in order to store it under the trailer for transport. The bracket of the dish mount just did not look substantial enough to make that modification. So, I decided to make it a 2 piece dish where the arm disconnects by sliding out of the bracket to make it small enough to store.
I took off the LNBN off of the arm and then removed the bracket from the dish mount. (4 Bolts) I then drilled out the 6 spot welds with a 1/4" drill bit, that holds the arm to the bracket. This allows the 3" long 1/4" stainless steel bolt with the wingnut to align and hold the arm to the bracket. I added a small plate by welding it to the bracket for extra strength. (probably not really needed)
I also used a Dremel tool with a grind stone to smooth the inside of the bracket so the arm could slide into it easily. The arm has enough space allowing the cable to pass down the inside of the arm, even with the bolts in place. I then gave it a coat of paint. (Doesn't really match) and assembled it using the 2 bolts.
It is still rigid and is in the same alignment as before.
Just remove 2 bolts and store away.
ID:	114158   Click image for larger version
ID:	114159   Click image for larger version
ID:	114160   Click image for larger version
ID:	114161   Click image for larger version
jbhiggins is offline   Reply With Quote
Old 07-15-2016, 11:15 AM   #2
Mr. Dan's Avatar
Great job!
Now come and fix mine. You're only about 150 miles away!
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 85 / 2017 = 14; booked = 28
Old 07-25-2016, 12:38 PM   #3
Took the RV this last weekend 373 miles north from home. I copied down the angle, skew and direction before we left. Put the 2 piece dish together and reset the pointing items for the area code we were in. Placed it up on the ladder mount and spun it south. I use an inexpensive satelite finder I got on Ebay. (8 bucks) when I got a solid beep, I locked it down and connected directly to the satelite connection on the back of the trailer. It worked perfectly as if I had not made it into a 2 piece dish. It also was able to get the local stations for our home area up there too! Happy campers!!
Old 07-25-2016, 12:42 PM   #4
BandJCarm's Avatar
OH MY. Great IDEA!!! You are my hero for today!!!
I'm printing this out. Not one hour ago, I was out trying to cram this thing into the basement storage. I promised myself NEVER to take it apart again! LOL
OR, come fix mine after you do Mr. Dan's.
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-25-2016, 09:45 PM   #5
This is what I got to shrink the size of the dish...
New Improved Universal Folding LNB Arm Kit #2
John & Mary Jo
Enjoying the adventure
Ky-N is offline   Reply With Quote
Old 07-26-2016, 07:08 AM   #6
I just take the three bolts off on the arm and stow dish in the basement. There is four but I only use three. The bolts are only finger tight, I really don't see a problem. I have a spot in the basement that's just perfect for the dish without the arm and it only takes a minute to fasten the arm back on.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
