Old 03-10-2012, 04:50 PM   #1
Connect Galley tank to Front grey water tank
Next project is to hard plumb the rear galley tank to the front grey water tank and eliminate the need to crawl under the slide out and hook another hose. 10' of 1-1/2" ABS, 3 connectors and a 1-1/2" slide valve and about an hours work.
Old 03-11-2012, 06:57 PM   #2
Got the connection made into the main drain elbow and the galley drain elbow as well as the 1-1/2" slide valve by the main drain. Would have been completed, but had to stop to design and build an alum support to mount the slide valve on to eliminate any push/pull forces on the slide valve and the connection to the main drain elbow. Only thing left to do is install the 1-1/2" sched. 40 ABS pipe between them. Also had to stop & watch the NASCAR race.
Old 03-11-2012, 07:04 PM   #3
TURBS's Avatar
Old 03-11-2012, 07:21 PM   #4
Connecting holding tanks
Progress pictures
ID:	10856   Click image for larger version
ID:	10857   Click image for larger version
ID:	10858   Click image for larger version
ID:	10859   Click image for larger version
Old 03-11-2012, 07:35 PM   #5
TURBS's Avatar
nice ! and ty !
Old 03-11-2012, 07:53 PM   #6
sherdep's Avatar
so far looks like a professional plumber is doing the install cause you are taking your time and not throwing it together
Lookin good and I also thank you for posting pictures
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 03-12-2012, 12:31 PM   #7
Finally got the job finished. Only leak was the factory elbow connection coming down from the holding tank. Don't like the plastic straps the factory uses to supposedly hold the connections to the frame, so I fabricated some alum. straps and drilled into the frame flange and secured it the way I think it should have been done. Even tho' the new pipe is not on a downward slope, but has to go up about an inch at the back, it will still drain the tank itself and leave about a quart or 2 of water in the 3" pipe/elbow, we never open the slide valve or uncap that connection so it shouldn't be a problem. Wasn't on our 08 831RLSS and it was plumbed the same way. The only tricky part of this whole operation is getting the hole in the 3" elbows drilled and hand filed to an exact fit for the 1-1/2" sched 40 ABS. The front was especially time consuming due to the fact that you can't drill into the center of the elbow. Also a little tricky is contouring the 1-1/2" pipe to match the inside of the front 3" elbow to prevent any "non-water" particles from hanging up or blocking flow.
Name:	Galley tank connected with Main Drain.jpg
ID:	10865   Click image for larger version
Name:	Inside view of new connection.jpg
ID:	10866   Click image for larger version
Name:	Rear Connection.jpg
ID:	10867   Click image for larger version
Name:	Inside view of Rear Connection.jpg
ID:	10868   Click image for larger version
Name:	New Alum Strap to Hold Drain.jpg
Old 03-12-2012, 01:33 PM   #8
Dave_Monica's Avatar
Nice job! Thanks for sharing pictures of the installation.
Dave
Old 03-18-2012, 09:38 AM   #9
Got mtn bike?
ddavis662's Avatar
WOW, nice work!
Makes my mod look lame LOL
But it did work, I really don't need the 2nd hose connector.
I would put this hose in the drain 1st and then shove the elbow from the main sewer hose to hold it. I would leave the valve open and let it drain the entire time.
ddavis662 is offline   Reply With Quote
Old 03-25-2012, 11:58 PM   #10
Thanks for sharing pictures.
Bruceh36 is offline   Reply With Quote
