Old 07-10-2011, 03:42 PM   #1
Connecting PVC to Trailer Sewer Connection
I plan on connecting my 5th wheel to the park sewer with PVC. I have found a 3" Flexible Rubber Coupling to connect to 3" PVC, can I connect this coupling to the existing bayoneted waste valve outlet? I don't want to change the existing setup on the trailer because when I move I will go back to the standard sewer hose. My trailer sits in one spot on the Gulf coast for about 6 months of the year and the sun is just deteriorating these flexible hoses.
Dennis
La Vernia, Texas
2007.5 Dodge 3500 Laramie, 4WD, Dually, 6,7L Diesel
2008 Forest River Sandpiper 375QBQ
dd5087 is offline   Reply With Quote
Old 07-10-2011, 07:17 PM   #2
I plan on doing the same thing. I just purchased the parts, but have not installed it yet. The RV parts store had a Rigid Pipe Adapter. It connects to the RV waste outlet, and has a 3" male pipe thread facing out. To this, I connect a 3" coupling, female thread x slip on (RV store has this also). From here I will simply run 3" PVC to my sewer. I think this is all you need. I am not sure if I will use any flex pipe at all in my hookup. If I do, I will likely put it on the end near the sewer tie-in(?).
Fab-5 is offline   Reply With Quote
Old 07-10-2011, 08:00 PM   #3
cedar creekin's Avatar
As long as there is enough room between the 4 studs on the sewer pipe and the actual valve to place a hose clamp, the rubber sleave will work.
I have done it before without leaks. It just takes a little work to slip it on.
2003 cedar Creek 36 RLTS
Pushing an F350 diesel
Trailair
US Navy Persian Gulf Vet 1991-1994
cedar creekin is offline   Reply With Quote
Old 07-11-2011, 09:13 AM   #4
This sounds like a better method, I will see if I can find that rigid pipe adapter.
Dennis
La Vernia, Texas
