Old 09-30-2016, 09:23 AM   #1
Connection for Flo-Jet pump
I recently bought a Flo-Jet macerator pump then tested it by filling up both the black and grey water tanks and pumping the waste to the connection on my septic system. I had to use a spare battery I had to operate the pump. I then decided I would have a connection for the pump right at the waste water valves. I happened to have some 10/3 wire from a job I did some time ago so I ran it up through the enclosed underbelly from the battery at the front to the valve area near the rear of the TT. I bought a connector to fit the pump's connection and left enough wire so that I could make the connection without having to crawl under the TT. I had to cut one end off of the connector I bought so I used it to make a place to hook the 12vDC wire to when not in use and to keep it clean.
ID:	121713   Click image for larger version
Thurman is offline   Reply With Quote
pump
