Old 10-24-2014, 09:03 AM   #1
Convert Cable in to Cable/Satelite in.
When you have a cable input only it is easy to convert it to a Cable/Sat input for a couple of dollars. I do it all the time.
This is the setup a lot of trailers have,
Name:	ImageUploadedByForest River Forums1414159311.463653.jpg
Just install 2 cable plates in series and the problem is solved.
Name:	ImageUploadedByForest River Forums1414159362.935890.jpg
Hopes this helps someone.
jwedell is offline   Reply With Quote
Old 10-24-2014, 09:56 AM   #2
bubbles's Avatar
Or, put in an A/B coax switch for the same price and not have to fiddle with removal/installation of a jumper.
Old 10-24-2014, 10:21 AM   #3
Kaadk's Avatar
Why bother with a jumper or a switch? Couldn't you just take the existing lead from the outside, put in a spliter and then run one lead to the existing cable/tv amplifier switch, and the other to the sat box? Then, when you're at the campsite, if you hook up cable, set the tv on cable and leave the sat box turned off. If you hookup sat, switch the TV to your sat box input and turn the sat box on?
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 10-24-2014, 10:37 AM   #4
Satelite will not work through a splitter.
Old 10-24-2014, 10:39 AM   #5
Not sure if it works through an A/B switch
Old 10-24-2014, 10:40 AM   #6
jimdd810's Avatar
Satellite will work through a splitter. If you have the right splitter.
Life is a highway!!!!!
jimdd810 is offline   Reply With Quote
Old 10-24-2014, 10:43 AM   #7
bubbles's Avatar
A/B switch like a straight shot. Works fine.
Old 10-24-2014, 11:02 AM   #8
Kaadk's Avatar
I know you can't split a satellite signal from one LNB to multiple receivers, because the LNB and receiver work in concert. But I figured it would work when only used on one leg, kind of like a coax coupler, but just with a spot to hook up a second 'unused' coax. As long as you don't have a receiver on the the second coax, it should behave just like a coupler. Of course you also have signal loss to consider, but I don't see much difference between a decent splitter and coax coupler.
Then again, I don't use satellite (or the cable for that matter) in my trailer, and my home satellite has all direct runs from LNB to each reciever with no couplers, so I've never actually tired it. I think I've got some couplers and splitters handing around here somewhere, I'm going to have to actually try it out and see what happens.
Old 10-24-2014, 11:10 AM   #9
Diplexers will allow you to receive both CATV & Sat over a single cable.
See attached sketch, and do a search on the net for diplexers or talk to a Radio Shack rep for a better explanation
Hope this helps.
mbtelguy is offline   Reply With Quote
Old 10-24-2014, 11:11 AM   #10
Hope this helps.
Yes it will.
