Old 07-20-2016, 08:00 AM   #11
Phat Phrog Stunt Crew
elind's Avatar
Originally Posted by mnoland30 View Post
I modified a propane stove to hook to the quick disconnect, but it doesn't put out enough pressure to cook well. The grill that came with my ROO doesn't put out much heat. You'd have to be really patient to cook on it. Anyone else have this issue?
Did you leave the BBQ gas regulator in the line after hooking it to the quick disconnect? The pressure in the quick disconnect line is reduced to 1/2 psi from your RV at the tank and a second regulator will reduce the pressure again. You need to remove the second regulator.
2014 Wildcat 327ck
2015 129 nites
2016 63 nites
elind is offline   Reply With Quote
Old 07-21-2016, 10:30 AM   #12
tossed the outide grill
Craigster MI,
I recall paying about $150 (but I sold my grill for $50). It's a 3 burner stove and looks like the rangetop on the inside. It's pretty big and sits high - but I'm 6 foot 3 and I like the height. Sorry I can't do a pic but I think if you went on the rockwood popup site you could find a picture. It does work great.
- dann
dannyeager is offline   Reply With Quote
gas
