Old 10-18-2014, 07:13 PM   #1
Converting TT Marker Lights to Turn Signal?
I know makers lights can easily be rewired to be turn signals, but has anyone done this? My 35' TT has a yellow marker light in the lower center of each side. I think it would be great if these were turn signals. Thoughts?
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 10-18-2014, 07:17 PM   #2
davel1971's Avatar
not hard to remove that one from the parking light circuit, but you would need to run a wire either from the rear light up to that light or be able to locate the signal circuit along the frame somewhere to tap into it
David & Lynn
Old 10-18-2014, 07:41 PM   #3
Blackrock's Avatar
You can use a two filament bulb type setup so you can have marker and turn signals both in the same fixture. Many types available out there mainly in the heavy duty trailer lighting products.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 10-18-2014, 07:51 PM   #4
davel1971's Avatar
this is probably the much better option. Disabling the side marker would not only be a bad idea, would also be illegal.
David & Lynn
Old 10-18-2014, 08:04 PM   #5
That would be perfect. I will have to look for one that is a close replacement for the current marker.
I thought of the legal issue. I wonder if center markers are required for a trailer over a certain length, or if FR just put them there out of goodwill. EDIT: NHTSA regs require a center marker light/reflector for trailers over 30' in length.
Lee and Anne
Old 10-19-2014, 08:13 AM   #6
Toy-aholic
you are going to need a converter to keep them from coming on with the brakes
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 10-19-2014, 09:15 AM   #7
davel1971's Avatar
you are right, since trailers don't have independent brake and turn signal circuits
David & Lynn
Old 10-19-2014, 10:31 AM   #8
JackFrostWinter's Avatar
That all depends on WHICH trailer(s) your referring to , because YES , some DO have seperate wiring connections for brake and turn signal as do certain cars and P/U's
Fun is where you make it
JackFrostWinter is offline   Reply With Quote
Old 10-19-2014, 01:40 PM   #9
TURBS's Avatar
I've not ever seen a camper with separate stop and turn.
That's normally not a cost that a trailer manufacturer wants to add.
Besides if your tv doesn't have separate stop and turn they wouldn't work anyway without installing a converter.
Turbs
Old 10-19-2014, 02:07 PM   #10
EVERy vehicle has seperate STOP and TURN ... and then they are commonly joined at the signal stat - aka directional signal/hazard flasher control .
light
