Old 03-14-2013, 10:21 PM   #1
rip
rip's Avatar
Countertop Extension - no more wobble
My optional countertop extension wobbled when mounted on my Windjammer 2809W. It was just plain dangerous with it's one leg design.
I thought about putting hinges on it to make it more stable, then realized my dinnete slide would close putting the table right up to the counter where the top would be fastened. Crunch.
Then, I thought about ordering another leg and mounting the old and new legs to provide equal left/right support. Fortunately I didn't do that before coming across one of Sid's reply threads about his solution, here's the link...
So, I went to Tractor Supply Store and picked up two 1/4" x 1 1/4" hitch pins. I mounted the extension firmly as he suggested, then drilled a 1/4" hole into each cabinet bracket mount continuing through the extension tab mount. I inserted the pins. What a huge difference and such a cheap simple solution!!!
His reply thread has better pictures, and I plan to add the line to hold the pins when removed. My pictures below show the pins right after I drilled the holes and inserted them, and the slide table stored and retracted right up to the counter cabinet where the extension mounts. Mental note, always remove extension before retracting slide, don't forget Ray. And, oh yeah, thanks Sid.
Ray
+ 2013 Rockwood Windjammer 2809W
+ 2008 GMC Sierra Crew Z71
+ 2002 Ford F-250 7.3L 4X4
rip is offline   Reply With Quote
Old 03-18-2013, 05:04 PM   #2
rip
rip's Avatar
Here are pictures of the two cables installed to hold the pins when the extension is removed. Made using nylon coated leader wire for fishing and aluminum leader crimps. Also pictured, the now stable extension...
ID:	25888   Click image for larger version
Ray
Old 03-20-2013, 03:19 PM   #3
clancythecamper's Avatar
Nice!
clancythecamper is offline   Reply With Quote
