Old 06-01-2011, 02:56 PM   #1
DAISY BOYKIN's Avatar
Cut your heat from the shower skylight
Being the shower in the 8285WS gets really hot from the skylight (does here in the hot summer sun), I found a "FIX" for the heat in the shower.
Went to Lowe's, purchased "GILA" Platinum window film. Removed the skylight from inside the shower (not the one on the roof) Applied the film to the bottom side of the shower skylight, the stuff rejects 99% of UV rays, is LOW-E (helps retain winter heat) Helps block heat and glare.
After installing the film, it reduced the glare and heat tremendously.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 06-01-2011, 05:35 PM   #2
okdrifter's Avatar
Great tip I'll be doing this next week.
Doug and Carmin
2010 Wildcat 31TS
2008 F-250 King Ranch
okdrifter is offline   Reply With Quote
Old 06-01-2011, 06:53 PM   #3
electromagn8's Avatar
any chance that you post a pic of that?
[/SIGPIC]
2011 Flagstaff 8528BHSS
2008 Toyota Tundra SR5
electromagn8 is offline   Reply With Quote
Old 06-01-2011, 07:40 PM   #4
tbritt's Avatar
May sound dumb but if you removed the inside part what is the bottom side?
2012 GMC 2500 HD
2011 303 RK LaCrosse Luxury Lite
Days camped 2010: 274
2011: 365
2012: 365
tbritt is offline   Reply With Quote
Old 06-01-2011, 07:53 PM   #5
Rugged Brown's Avatar
I think he means the bottom or inside side of the outer layer. confused. sound sensible when i wrote it.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 06-01-2011, 08:06 PM   #6
tbritt's Avatar
Think I got it now...thanks
2012 GMC 2500 HD
2011: 365
2012: 365
Old 06-03-2011, 06:00 AM   #7
Stop the heat in the shower on the 8285ws
I think you got it right about what I removed ?? It is the part that is on the ceiling in the shower. It has a clear, flat plastic (maybe Lexan ??) window in it. I applied the film to the bottom side of the clear flat plastic, carefully trimming the film to fit just the clear flat window. You can still see through the window as if nothing has been applied. But what a difference it made in the shower/ bathroom. the procedure has reduced the heat by at least 75%. This really helps the A/C by reducing the heat.
I was about to spray paint the clear flat window white, but thought I would try the "GILA" platinum film first.
Sure glad I tried the film first
Old 06-03-2011, 10:59 AM   #8
Villa Estate 392FLFB
The_Stuff's Avatar
i wonder how well this could be applied to all the windows in a TT
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 06-03-2011, 11:15 AM   #9
Brush's Avatar
We bought Solar Door Window/Vent Covers from Camping World for the bedroom door as well as the shower skylight and they keep the heat and light out. It's held up with velcro/sticky tape and can be removed easily.
Worldwide Merchandise Company - Solar Entry Door Window Cover, 24" x 16" - Window Covers - Camping World
Bill and Darlene
2008 Tundra 5.7, 4.30 axle, 8' Bed, 4WD, Super Springs
2009 Rockwood 8319SS Reese WD hitch
Nights camped in 2018(0) 2017(25) 2016(31) 2015(34) 2014(37) 2013(36) 2012(37) 2011(21) 2010(48) 2009(33) 2008(18)
Brush is offline   Reply With Quote
Old 06-03-2011, 12:43 PM   #10
Cut your Shower heat by 75%
I also bought the "WOOLIE" "FUZZY" insulators that push up into the crank open vent in the bedroom and living room. I also have the MAXX-AIR II's
on all the crank up vents.
Someone ask about the film being applied to all the windows, I'm sure it would work. You can see through the film from the inside as if nothing was there. But when you look at the film from the outside, it has a mirror appearance.
