Old 03-31-2013, 07:00 AM   #1
camper1999's Avatar
Cutting a hole through corian
I want to add a water filter with dispenser to my kitchen sink. My counter top is corian. I need to drill a hole through the corian to install the faucet. It look fairly simple. Has anyone done this and/or ran into any issues?
2011 GMC 2500HD Diesel
Old 03-31-2013, 07:07 AM   #2
Corian is a plastic composite. It can be drilled, routed and sawed. A forstner bit will work but drill slow to avoid building up heat. Those bits also come in a variety of sizes that will work for a your sink fixtures.
TeJay
TeJay is offline   Reply With Quote
Old 03-31-2013, 08:00 AM   #3
Herk7769's Avatar
TeJay
X2 and also the caution about over speeding the bit.
Corian will burn (brown) if overheated.
HAM CALLSIGN - KC3FFW
Old 03-31-2013, 08:29 AM   #4
dmf564's Avatar
When I work in a counter top and cabinet shop we always used paddle bits for straight holes like your wanting. Just use a new bit and don't let the shreds fill the hole as your drilling. If at all possible have a shop-vac running to keep it clear.
[SIGPIC]TV-2012 Ford F250 XLT Supercrew 4X4
TT- 2010 Jayco Jay Flight 17Z (traded)
TT- 2012 Coachman Catalina 30BHS (current)
Me and my wife with 3 kids love camping!!
dmf564 is offline   Reply With Quote
Old 03-31-2013, 08:42 AM   #5
Denver, CO
garbonz's Avatar
Hole saw works fine also, run slow, drip water, be patient. Piece of cake. Works on real granite also.
2017 Fuse 23T
Old 03-31-2013, 02:17 PM   #6
camper1999's Avatar
Thanks all
Old 04-05-2013, 08:38 PM   #7
Hole saw is your best best, done it several times on home counter top. Didn't use any water/lubricant, just slow steady speed and light pressure.
Sirsea is offline   Reply With Quote
Old 04-06-2013, 01:10 PM   #8
camper1999's Avatar
Done and success.
Old 04-06-2013, 01:34 PM   #9
So, what did you use? Hole saw, paddle bit?
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 04-06-2013, 01:47 PM   #10
camper1999's Avatar
Hole Saw. It worked great.
