Closed Thread
Old 07-02-2016, 01:33 PM   #11
Thanks for the info. We notice our new unit did not have locks either. My wife was like oh we need to get some, then I asked when was the last time we locked the bathroom door at home or in the last two campers? She thought, then said, never mind.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline
Old 07-02-2016, 02:24 PM   #12
AquaMan's Avatar
I don't see the need for a lock. Our rule is, if the door is shut, someone is in there, and if not sure, you knock first. We don't use locks in our home either.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
AquaMan is offline
Old 07-02-2016, 02:40 PM   #13
asquared's Avatar
Our first tt had a lock on the bathroom door. First trip out dd then 3 1/2 yrs old locked the bathroom door. Fortunately she wasn't in there, she had locked all of us out of it. DH had to disassemble the handle as the hinges were in the inside. this took awhile and we were fortunate to have the right tools with us. I can only imagine if that was hot weather and she was on the other side. The bathroom is small enough that busting in the door could hurt someone on the other side.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline
Old 07-02-2016, 02:50 PM   #14
Usually Confused Member
emm-dee's Avatar
Every bathroom and bedroom door in my house has a "lock". But, like mentioned earlier, all can be easily unlocked with a small coin or inserting a toothpick. And it's going to stay that way.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is offline
Old 07-02-2016, 02:51 PM   #15
jtstromsburg's Avatar
Originally Posted by OldCoot View Post
Can't little sister be taught to close the door?
Yes and she has. She was two at the time and needed a little "persuading" to get to where she'd remember. That was our previous fiver that I wrecked. Haven't added locks on our new one. I was just adding to his point to make sure you have a way in easily.
Good thread and I hope many read it and think thru it rather than get defensive like we all typically do.
Love this forum for all the info that gets shared!!
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline
Old 07-03-2016, 12:20 PM   #16
By design, these door locks cannot be locked so that people cannot get out, only to stop people from getting in. All one needs to do is turn/ pull the door handle/ knob. Nothing at all wrong with locks on the door.
Jim & Pam
Ram 2500, Crew Cab
2014 Hemisphere 327res
JP Camper is online now
Old 07-03-2016, 12:43 PM   #17
Telstar's Avatar
I swapped the bathroom lock set for the type every home bathroom has. Problem solved.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline
Old 07-03-2016, 01:28 PM   #18
genehorn's Avatar
That's a good tip for many. I put a locking knob on ours and put the emergency unlocker in the kitchen drawer. Our bathroom also has an outside door. In our case we can have privacy with safety.
genehorn is offline
Old 07-03-2016, 02:12 PM   #19
Oaklevel's Avatar
Yes and no a child does not always know how to open the door an as the old refrigerators may get trapped inside and in this case die from the heat......... it can happen. Putting a lock on an RV door is putting a child in danger of death.........
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is offline
Old 07-03-2016, 02:20 PM   #20
I appreciate Oaklevel's concern and sharing of his/her experience. I'm sure it was a scary situation.
But to each his own. I wish I had a lock on ours. RV bathroom doors are so flimsily made, one good push or kick would most likely bust it open. But then you have a damaged door frame.
2017 Ford F450 Lariat 6.7L
2016 Vengeance Touring Edition 40D12
Former Forest River Campers:
2004 Puma 30FQSS
2010 Sabre 31QBDS
2014 Work & Play 30WRS
KFX450RXC is offline
Closed Thread
door, roo, lock
