So I have a few pictures to update everyone on the status of the inverter and auto transfer switch install.
First a picture of some of the equipment and tools I used to complete the install.
Next I had to remove the double light switch for the through storage light and the light by the king pin hitch. This was removed so I could cut the hole to install the inverter.
Once the switch was removed I made a template of the inverter out of cardboard and cut the hole for the inverter in the 3/4" plywood between the through storage and the factory battery storage compartment.
This was the best location I could find for the inverter due to the close proximity to batteries and the 12 VDC terminals for the camper DC power supply. (I removed the original 12V battery when we bought the camper last summer and installed 2 new 6V golf cart batteries in the front storage compartment.)
The Go Power Automatic Transfer switch is installed behind the finished wall in the through storage compartment. (I forgot to get a picture of the transfer switch install location to post. I will do that when I go to the fifth wheel next time.)
I removed the converter/charger from under the main electrical panel and installed it inside the factory battery compartment with the inverter and tied it into the transfer switch as per the schematics supplied with the Go Power Auto Transfer switch.
I have a few more things to do in order to put the system in operation. If you are interested I will post more pictures and description of the work I complete as I go. Hope you enjoy the post!
