Old 08-18-2010, 01:47 PM   #1
Jan Goldfield
pondlady's Avatar
Dead bodies under the bed
Remember all that inaccessible space under the 28bh bed. You could use the space if you lift a piece of the heaviest plywood ever made that has your mattress on the top of it. Someone here suggested storing dead bodies under there, another spare tires or flat ones.
Not to be deterred nor wishing to disturb all those bodies or tires, as the case might be, I used one plumbing access panel on each side of the bed.
Behind the access panels I put plastic tubs on their sides. I can put anything in there now except bodies or tires. The biggest problem is their *whiteness*. Several wrinkled and crumpled up pieces of contact paper later, I might learn to like white or just put the bedspread sideways.
Jan Goldfield and Donna Morse
Slidell LA
2009 Cherokee Grey Wolf 28BH
2009 Ford 150
pondlady is offline   Reply With Quote
Old 08-18-2010, 01:55 PM   #2
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Gee, it might have been a bit easier to have someone install gas struts on the bed to help lift it.
dimurrrw is offline   Reply With Quote
Old 08-18-2010, 02:00 PM   #3
Jan Goldfield
pondlady's Avatar
@dimurrrw You like helping me spend money. I could just see the struts giving way on my fingers....or head.
Slidell LA
2009 Ford 150
Old 08-18-2010, 02:27 PM   #4
The bed in our trailer has the gas struts to hold it up, but after we put the memory foam over top of the mattress, it is a bit heavy for them. I went to the store and bought an expandable shower rod and use it to prop up the bed when I need to get under there. It works fine as long as you don't hit it.
Hokiehall is offline   Reply With Quote
Old 08-18-2010, 02:54 PM   #5
MrT
MrT's Avatar
Well, in the event that you decide to put higher-capacity struts in, please consider doing the Grand Rapids economy a favor by purchasing SUSPA-brand struts.
2017 Cedar Creek 38CK Hathaway Edition
2015 Ford F-350 6.7 CC 4x4
B&W RVK3300
Full-timing since 5/2/2016. Roam Sweet Home.
FROG Int'l Rallies: 2012-2017
MrT is offline   Reply With Quote
Old 08-18-2010, 02:58 PM   #6
Jan Goldfield
pondlady's Avatar
I have memory foam on top of the mattress as well. Makes for one heavy load to pick and hold up. I like my access panels - except for that *white* problem. Maybe I will paint them.
Slidell LA
2009 Ford 150
Old 09-09-2010, 01:58 PM   #7
Send a message via AIM to pjeffreysr1
In our 2010 Wildwood 26bhxl I use a piece of 1 1/2" pvc as a prop. We store our "wired" camp 'cook' table (used for electric skillets/convection oven/etc outside) I am definitely looking onto some gas struts. Any suggestions as to barnd/strength I should use? Havw a mattress w Queen size 4" memory foam topper.
pjeffreysr1 is offline   Reply With Quote
Old 09-09-2010, 02:10 PM   #8
Jan Goldfield
pondlady's Avatar
I couldn't even pick up the plywood with a mattress and 4" of memory foam on top. So access panels were my only option.
If I need room for bigger stuff, maybe I will have a look at struts. Like you PJ, I am looking for suggestions.
Slidell LA
2009 Ford 150
Old 10-22-2010, 08:47 AM   #9
You all just found a use for those almost useless slide locks that a lot of us have, but can't figure out how to use! Use them to hold up the plywood while accessing the compartment. Randy
Old 10-22-2010, 09:00 AM   #10
Jan Goldfield
pondlady's Avatar
For me it's the lifting of the plywood to begin with. I destroyed one shower rod and resorted to using a Leki hiking stick to hold the thing up. Just once. That was right after we started this month long voyage and the plywood has not been lifted since. I will have gas cylinders installed when we return home.
Slidell LA
2009 Ford 150
Old 10-22-2010, 09:21 AM   #11
I think you will really like those, Pondlady. We have actually had to adjust ours down on a Wildwood we had, as they were so strong the bed would "float" if we weren't careful.
You certainly should be able to lift it rather easily once the struts are installed. And you will love the storage.
Nights camped in 2010 = 21 nights
2008 Chevy CCab 5.3L 4WD Z71
2008 FR Surveyor 291
Champion Genset
Slpybear, Mrs Slpybear, Three Cubs
slpybeartx is offline   Reply With Quote
Old 10-22-2010, 04:09 PM   #12
yvesm's Avatar
Get gas springs and accessories here
McMaster-Carr
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 10-22-2010, 08:41 PM   #13
Fire Instructor's Avatar
My 2607 was similar in design. The under bed plywood was screwed down, and there were two small drawers installed under the bed, one from each side.
I unscrewed the plywood, installed a long piano hinge. I then uninstalled the drawer systems, unscrewed the drawer-face from the drawers, installed hinges and a magnetic catch, and made them access doors.
After attempting to find a proper size/strength gas strut with the right monting brackets, I gave-up and made a prop-rod out of an old broomstick, with a "socket" for it on the underside of the plywood made out of a screw-on door bumper.
I now have the entire under-bunk area, where we store extra bedding - an extra quilt, extra sheets, two comforters, extra pillows, a step stool, the "spare" globes for the awning lights (red, white, & blue for holidays), and a couple of games.
Much better use of the space! Anyone want/need any drawer hardware?
BTW - Total job cost, less than $30, with the piano hinge being the most expensive part.
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
Fire Instructor is offline   Reply With Quote
Old 02-03-2011, 06:13 PM   #14
Any chance you can re post the pics?
2010 Cherokee Grey Wolf 28BH
86ish palomino slide in
2000 F250 superduty 4x4 7.3/6speed crew/ short
edman87k5 is offline   Reply With Quote
bed
