Old 08-09-2013, 02:14 PM   #1
Kaadk's Avatar
Did I install my MaxAir wrong?
So, I've finally gotten around to doing some mods/updates on the TT yesterday (Separate thread coming soon on that topic once they're all finished.)
One of the first mods I did was install some MaxAir covers over my vents. I'm concerned that I may have left too much of a gap in the covers. I know it says some gap is normal, but since I installed the brackets over the existing caulking the gap is fairly significant.
I'm worried that with this large a gap, highway speeds might try to rip them off.
Mike
Old 08-09-2013, 02:19 PM   #2
TomStacey616's Avatar
Mine have a small "tilt" towards the front... No worries.. drive on and don't look back!
2010 Tundra DC SR5 TRD 5.7L towpkg (gone)
2008 F350 Lariat CC DRW 6.4PSD
2013 PT Tracer 3200BHT
BlueOX SwayPro (used when hauling cart too)
TomStacey616 is offline   Reply With Quote
Old 08-09-2013, 02:53 PM   #3
MOD Guy's Avatar
What you will find is that the gap allows tree leaves to get under and into the vent area. They can be a PITA. I would add some foam weather stripping around the edge to seal it from this type of debris.
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
Old 08-09-2013, 02:59 PM   #4
KyDan's Avatar
What he said-- get you some extra thick foam weather strip and put the
sticky side towards the MaxxAir cover. Re-install.
Forget about it for a couple years.
I just removed mine and cleaned the vent covers inside.
GRUNGY! But that's 1000s of miles and 4 years sitting in an open shed.
Not too bad and the clean up only took about a half hour each.
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 08-09-2013, 09:48 PM   #5
Kaadk's Avatar
Thanks for the tip. I feel better with the weatherstriping added.
Old 08-11-2013, 01:40 PM   #6
One of my MaxAirs blew off in a high wind. I guess after a few years the plastic gets brittle and weak around the bolt holes. When I replaced it I drilled and placed a 1 inch wide aluminum strip between the bolts to provide a more secure mount.
jpol is offline   Reply With Quote
Old 08-12-2013, 01:20 PM   #7
Jjs2000z's Avatar
I would have suggested getting the camco vent cover. This one allows the vent cover to be removed and cleaned. As well as removing debris that get between the vent. I got mine on amazon for $20
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 08-14-2013, 02:57 PM   #8
I have the same covers and I noticed that the previous owners bent the brackets down some to lower the cover.
2004 Dodge Ram 1500 Quad Cab 4x4
2008 Rockwood Roo 23SS
two_peases is offline   Reply With Quote
Old 08-15-2013, 04:28 AM   #9
You can buy (Hinge Kits) from MaxAir that allow instant open to clean. They fit the standard & MaxAirII covers. Youroo!!
Old 08-15-2013, 07:24 AM   #10
I would be careful with the foam strips. you do not want to trap moisture under there.
Bill And Theresa Perry, At Lake Gaston
2004 R Vision Trail Lite
2003 F 150 Super crew with 5.4 Tow package
bill and theresa is offline   Reply With Quote
