Old 09-28-2015, 02:22 PM   #51
Head Rambler
Well you guys cost me more money. I went to Lowes and bought the fence post, caps, gutter & internal gutter ends. Then I went to Ace and picked up some tiny eye bolts. I already had the metal strapping too use for the supports. So, now it's done. I'll post pics once it's under the RV.
Gotta go campin!
Old 09-28-2015, 02:26 PM   #52
Left Coast
It's always better to spend someone else's!
Old 09-28-2015, 02:53 PM   #53
King Yankee's Avatar
Send a message via AIM to King Yankee Send a message via Yahoo to King Yankee
Bama, is that an Engineer cry? As Bob said, its nice. I'm curious if any class A have one this.
Bruce & Nancy Richardson
Lexington GTS 300 S/S
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
King Yankee is offline   Reply With Quote
Old 09-28-2015, 04:59 PM   #54
leefl's Avatar
Originally Posted by bob caldwell View Post
Isn't Rinio flex a 3" hose? If it is, it'll fit with the hose ends on, just not the adaptor from hose sewer end to sewer pipe.....have no trouble with mine.
I have the dump adapter at the other side, but from memory (it's at the storage place atm), the hose would be an okay fit, but the bayonet adapter is about 4" diameter, so that would get stuck behind the gas pipe.
It should only take me 15-20 mins to make a new pair of brackets anyway, then I can decide which to use when I go back to the storage place to finish install.
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 09-28-2015, 05:15 PM   #55
Just got done doing mine last weekend, did the hinge and clasp but I really like the simple screen design.
Hornnumb2 is offline   Reply With Quote
Old 09-29-2015, 10:40 AM   #56
King Yankee, I did this on my class A. I built my brackets out of threaded rod. It fits just inside the storage doors. Need to have them open to pop the cover off either end.
2011 Georgetown 337 2011 Chevy Impala
pakkdad is offline   Reply With Quote
Old 09-29-2015, 02:08 PM   #57
golfmedik's Avatar
I took 1" square aluminum tubing and cut two equal lengths for each side. Held them in place with two C clamps and drilled through both pieces and the lip of the frame. I took 8" X 1/4" bolts with nylon lock nuts and put them through the holes with the nuts just to hold them in place(both sides). I then slid the posts between the two aluminum tubes, got them centered and tightened. This tubing will alleviate having to notch the posts around the propane lines.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 09-29-2015, 03:03 PM   #58
leefl's Avatar
Nice idea, actually sounds easier than what I did with folding 1.75" 18ga steel plate (same stuff that doc73 used) to shape, but making the new brackets 3/4" taller than the post, in order to clear the propane line. Anyway, done now, and should hopefully install tomorrow morning.
If I run into any unexpected issues then I'd probably use your idea, since it actually sounds easier to just drill two 5/16" holes (I used bigger bolts) through the square tubing), but hopefully these should work just fine.
Old 09-29-2015, 08:51 PM   #59
2007 WildCat 32QBBS
05CrewDually's Avatar
4 beam flange clamps and fender washers is what I used. I had to shim it down a couple of inches anyways because of the body panel. Less holes drilled in the critical flange is always a good thing. Plus it gives adjustability.
05CrewDually is offline   Reply With Quote
Old 09-29-2015, 09:49 PM   #60
leefl's Avatar
If the chassis frame beam/flange was exposed is have been very tempted to do the same, but I wanted to avoid cutting holes in the under "skin" or trim, plus there's some wood between the frame and the body shell/skin
