Old 07-23-2015, 12:12 PM   #1
Who Dares, Wins
doc73's Avatar
Did the Sewer Fence Post Holder
I have beating around the bush for some time to do the fence post holder for our sewer. So finally had some time off and put it all together yesterday.
Overall I am very happy with how it turned out. I will leave it as is and if the white bothers me I'll paint it black to match the trailer. I mounted it just forward of the midship jacks to allow for access to the jacks. I did not put it to the rear since the tanks are there and I did not want to risk dragging it.
I was able to get all that I needed, including the fence post, at Lowes. The cost was just under $70 for everything. I was going back and forth on how to mount it and make the access doors. Stole a few ideas from other and put it all together..
Here is a copy of the receipt from the Lowes. It has all that I bought for this setup. Only two things were different and I will get to those..
Bought the 8ft 5x5 fence post and 4.5" gutter in a 10ft length. Made the brackets out of some 1 1/2" plate steel with holes pressed into them. Used my vise to make them. It actually was easier than I thought it would be considering I had only a hammer and the shop vise. Just took some patience.
I decided the leave the fence post uncut at the 8ft length. I would be just as wide as the trailer (It will stick out a bit with the caps on). I just cheated it to the driver's side a hair so it is slightly out on the driver's side to avoid the side of the road. The brackets were held up into the frame's lip using a few self-tapping screws.
The lid design I stole from someone who had done it before me. I Used the standard caps, two springs and four cotter pins per door. Used 3 1/4" x 1/4" springs and 1/8" x 1 1/2" cotter pins. As you'll see in the photos I initially mounted everything centered up.. But when the gutter was slid into the post the would get hung up on the cotter pins. So I moved them up to be above the gutter.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 07-23-2015, 12:13 PM   #2
Who Dares, Wins
doc73's Avatar
Continued...
Once they were all drilled and bent it allowed me to keep the door closed but easily flip it out of the way to access the hoes. I did this on both sides of the trailer. The cap is tightly fitting but not so hard as to strain the springs. In the first picture you can also see a screw was added with a lock washer to keep the post from sliding side to side. It was a tight fit with the brackets but it is a safety, if you will.
Gutter clearing the lid mounts. You can see the original holes that got bound up.
Now the part that is different in the receipt from above. I originally bought two outside caps and one inside cap:
INSIDE CAP:
OUTSIDE CAP:
As it sounds, the OUTSIDE caps are for the end of a gutter. As you can see they have a nice rubber seal to made the ends waterproof. BUT, because of the seal and how they mounted (outside the gutter) they would not fit into the fence post once a fixed, they were a 1/4" to fat.
The INSIDE caps mounted inside the gutter not making it any wider. These did not have a waterproof seal and did not snap into place like the end caps. I solved this issue with some pop rivets (so as not to add width to the gutter) and some silicone sealant to keep the bad stuff in the tub. I added a third cap to keep the threaded part of the hose in place as well.
So after a couple hours of work and a few glasses of iced tea all worked out well. The gutter easily slides out both sides and everything fits nicely and neatly. Even without the screws I added as safeties the thing is rock solid in itsí mounts. I have a Rhino Flex 15ft hose with the threaded 90 campground hook up and a Rhino Flex 10ft extension hose packed in the gutter. With all this in the gutter I have about 1 or 2 inches to spare.
Link to all the photos:
https://plus.google.com/photos/10538...39945882513169
2015 ChevyHD D-Max
Old 07-23-2015, 03:44 PM   #3
panthercity's Avatar
Slick!
Certified JB Welder. Certified 3M Duct Tape installer.
Certified Farmer's Co-Op bailing wire expert. Graduate of the "Rock on the side of the Trail as a Hammer" school of motorcycle repair.
Getting old is just a matter of narrowly missing all the things that kill you.
panthercity is offline   Reply With Quote
Old 07-23-2015, 03:58 PM   #4
Zhanna's Avatar
Very, very nice!!!
2005 Dodge Ram 2500, 4x4
2017 Heritage Glen QBUD312
Zhanna is offline   Reply With Quote
Old 07-23-2015, 04:16 PM   #5
Pauls Toy Hauler's Avatar
Very good. I will get around to this one day. for now my sterlite container will have to do.
2015 Palomino Puma Unleashed 351-THSS 37' Toyhauler
2016 F-350 Platinum DRW 4x4 w/ Curt Q24 hitch and Air Lift rear air ride
"Just put that hammer down and give it hell" -Jerry Reed
Pauls Toy Hauler is offline   Reply With Quote
Old 07-23-2015, 05:32 PM   #6
cowboy72's Avatar
Nice job!
cowboy72 is offline   Reply With Quote
Old 07-24-2015, 08:21 AM   #7
nice job, I like the spring loaded end caps and how you used the cotter pins to keep the inside protrusion to a minimum
fella10 is offline   Reply With Quote
Old 07-24-2015, 01:48 PM   #8
Very nice, and neat. Just what I needed to get my project complete. AND, Thanks for the pictures that puts it all together.
kenenn is offline   Reply With Quote
Old 07-24-2015, 02:09 PM   #9
Thank you! I have been wondering where / how to do the same thing on our Wildcat. We too use the Rhino hose and it won't fit in the tail tube storage and I didn't want to mount something under the tail where it could get crushed if I was unlucky enough to get that steep driveway with the trailer. You install solved a bunch of questions for me. Again, THANKS!
Tdbrn is offline   Reply With Quote
Old 07-24-2015, 09:06 PM   #10
Who Dares, Wins
doc73's Avatar
We also have a steep driveway. I do not need an axle flip but I am close for sure... Thank you all for the kind words. Glad I can help some of you all out.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
