Old 06-19-2011, 04:22 PM   #1
BigDogD's Avatar
Lightbulb Different take on stove top counter space
Needing more counter space I took another members (michol02) advice in the thread Suburban Stove Top - Flimsey at best and purchased a Paula Dean butcher block cutting board @ Wally Mart. My wife did not want to do away with the Suburban heat shield / splatter guard (even though flimsey & contrite) - so I came up with a way to lay/mount the cutiing board on top of the closed stove splatter shield. I installed four rubber feet w/screws from the Home Depot hardware isle on the bottom of the board so they would "grip" the angled sides of the splash shield. It just so happened that the rubber feet are also angled closely to match the sheild sides. I also added four felt pads to the board @ the corners of the sheild to keep the board from scratching the top of the splatter guard. So, in the end just another idea if you want to keep your guard in place. As far as towing with this in place.... I think it will ride fine in place - if it doesn't I will follow up....
ID:	6424   Click image for larger version
ID:	6425   Click image for larger version
2004 Dodge Ram 5.7 HEMI SLT Longbed
2012 Rockwood ROO 21SS
Wife - Kaede & Gidgee (Our Girls)
BigDogD is offline   Reply With Quote
Old 06-19-2011, 07:12 PM   #2
The Old Man
Willis's Avatar
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
Willis is offline   Reply With Quote
Old 06-19-2011, 07:19 PM   #3
Nigels's Avatar
Looks great, do you have it hinged at the back?
Nigel & Bev
Brit Driver & Canadian Naviguesser
2011 Rockwood Signature Ultra Lite 8280ws
2011 Dodge Ram 3500 4x4 Diesel
Nigels is offline   Reply With Quote
Old 06-19-2011, 07:29 PM   #4
mike54's Avatar
looks good I took the flimsy tin crap off and put the cutting board on as the cover
Mike & Marsha
2011 Signature Ultra Lite 8319SS
2005 Dodge Ram 3500 5.9 cummins diesel
http://www.facebook.com/WestAllisSunshiners
mike54 is offline   Reply With Quote
Old 06-19-2011, 08:53 PM   #5
rrdrtravelers's Avatar
Great idea. If I didn't already have a solution, I would have my hubby make me one of these. We use the hard plastic black stove cover we bought from Camping World several years ago. It has that rubber grip shelf liner stuff attached to the bottom so it grips the metal stove cover. Travels well and gives you the added counter space. Only thing I don't like is the knife marks it leaves when using it as a cutting board. But since it works well and the money is already spent, we'll use it until it's no longer functional. I love your cutting wood block solution alot better.
2011 Cedar Creek 36RE
2002 Ford F350 Crew Cab 4x4
rrdrtravelers is offline   Reply With Quote
Old 06-20-2011, 08:20 PM   #6
BOBFIDY's Avatar
Pimped our SALEM stove top
Thanks to a lot of other folks fixing up a stove cover...I fixed ours up today using a number of others ideas.
Got the Paula Dean cutting board from Wal-Mart, closet rod holders and 3/4" long screws from Lowes...the screws with the rod holders are TOO LONG...Be careful.
I placed the rod holders just outside of the grill rods that run front to back, used the rolled up tape trick to place the cutting board, drilled pilot holes, screwed the holders on...and IT WORKS GREAT.
Placing the rod holders just outside the front to back grill bars keeps the cutting board from moving anymore than about 1/4" side to side.
As solid as it is I dont think there will be any problem with it riding in place on the road.
Thanks to all of the ideas...AND.....HAPPY BIRTHDAY NANCY.
ID:	6440   Click image for larger version
ID:	6441   Click image for larger version
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 06-21-2011, 05:28 AM   #7
BigDogD's Avatar
No, it is totally un-attached & can be picked up & removed
BDD
Old 06-22-2011, 10:25 PM   #8
What size board or do they sell only one size?
Also does Walmart sell the rod holders?
Al
ALMcKinney is offline   Reply With Quote
Old 06-23-2011, 03:50 PM   #9
BOBFIDY's Avatar
Al
The board I got was 18" x 21" I think...and I'm sure Wal Mart sells the rod holders. I always go by Lowes to find stuff that I know they have...since I retired from there 10/10/10.
Good luck making yours work.
BOB
Old 06-26-2011, 07:52 AM   #10
Thanks,
I did mine yesterday bought the PD cutting board 22"x 15" at Walmart and the rod holders at Lowe's.
It looks great and my wife loves it.
Thanks again,
Al
