Forest River Forums
Sunline User Photos
Old 01-11-2012, 03:23 PM   #11
Moderator
acadianbob's Avatar
Originally Posted by DAISY BOYKIN View Post
The analog thermostat has a +/- of 6° swing, where the digital has a 1-1 1/2° swing for start and stop of AC and Furnace which is more precise.
And this is the big benefit.
http://i421.photobucket.com/albums/pp297/acadianbob/IMG_2757.jpg
2012 F150 FX4 Ecoboost, 2008 Surveyor 235RKS
2003 Yamaha FJR1300, Reese Dual Cam WD
1969 John Deere 1020, 1940 Ford 9N
Jonsered 535, Can of WD-40, Hostess Cupcakes
Old 01-11-2012, 04:59 PM   #12
For us the AC is more in the heat. We have a 3 minute wait with Honeywell.
Acadia - We use to have a Fork Lift for peaches on a 8N ford and a 9n Fergie.
Portagie1968 is offline   Reply With Quote
Old 01-13-2012, 05:52 PM   #13
Originally Posted by flugelboneman View Post
2010 Rockwood 2304s - struggling with replacing analog for digital. I am getting a range of confusing data, even from the local RV techs. I have found an Atwood Digital that says it simultaneously controls furnace and roof top air. $229.00. So asked tech for approximation of installation cost. He responds that he can't tell till he gets the new thermo and determines whether he has to reconfigure the AC wiring. If not necessary, very small job, but if necessary much labor to run wires. Do not want to pay big dollar for thermo then find that it is another big bill for installation. The Atwood part # is 1053-1 38555. Has anyone done this mod? I am not hung up on Atwood, but would sure like to find one that is quickly compatible with my Suburband furnace and Dometic roof air. My current thermo controls both, so the wiring is there.
Check here, looks like MikeA may have a solution.
http://www.forestriverforums.com/forums/f16/thermostat-manual-18894.html#post153307
ab
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 02-18-2012, 05:30 PM   #14
I recently replaced my "Dometic" thermostat with a "Hunter" from Wally-World, cost of about $20. The old unit would continue to run long after the set-point for either A/C or heat had been reached. I had to play a bit with the wiring as my old one was a six wire set-up and the new one only used four wires. I did not add the extra switch for "Hi/Lo" fan as the low speed was enough. Odd thing was the green wire turned out to be the "HOT" wire in all this. I did not use the "RED" nor "BROWN" wire on the new unit. All is well now.
Thurman is offline   Reply With Quote
Old 02-27-2012, 10:58 AM   #15
I installed a Hunter Programmable Digital T-stat in our last 3 campers. Takes about 10 minutes. FYI I put in the hi/lo fan speed switch but leave it on high mostly.
» Online Users: 528
92 members and 436 guests
12vdzl, 4bnabird, Adony, Al Fresco, amxpress, Big Vic, Biscuit, blaisrv, bowshark, bozemancamper, Buffalohunter, campnqueen, Canuck_Doug, Char_n_Kath, cousin01, davidjb, daw592, DonG, donh, donn, duchie, Elidh, Emptypockets, f1100turbo, firedaniel, fx4roo, gandr96, gimp425, Gman88, gucci, herk7769, heytomgraywolf, honda1, hoovercab, Iggy, jacksum2, Jeep4Two, JJFerg, Joseph5410, kb4srn, ken0042, KKapa, KRS, Lumpty, mack63, Mad4sax, maggiek, mamentt, manvel, mike1329, milw156, mraynie, mtl roofer, NeilM108, newby, NO3putt, ohiobill, okdrifter, PrairieBoy, railstar, rburk015, rickthelen, RickV, RJHuser, rkswyo, RV Guy, Sahgie, Saratoga Camper, Sawdr73, sherdep, sideout1961, softwarejoe, sprayking, spurge1947, stevem4134, thewren, Timex, Tincup13, Titleguy, Top B, TopGobbler, troyt, ugeesta, venturetaz, Vette4trcr, wbdvt, Whiteknight, whj77372, will4u, wnytaxman, wvfireboss, Zama
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
