Forest River Forums
Sunline User Photos
Old 12-08-2011, 12:30 PM   #1
Digital Thermo
2010 Rockwood 2304s - struggling with replacing analog for digital. I am getting a range of confusing data, even from the local RV techs. I have found an Atwood Digital that says it simultaneously controls furnace and roof top air. $229.00. So asked tech for approximation of installation cost. He responds that he can't tell till he gets the new thermo and determines whether he has to reconfigure the AC wiring. If not necessary, very small job, but if necessary much labor to run wires. Do not want to pay big dollar for thermo then find that it is another big bill for installation. The Atwood part # is 1053-1 38555. Has anyone done this mod? I am not hung up on Atwood, but would sure like to find one that is quickly compatible with my Suburband furnace and Dometic roof air. My current thermo controls both, so the wiring is there.
flugelboneman is offline   Reply With Quote
Old 12-08-2011, 12:40 PM   #2
Go to WalMart and buy yourself one of the basic Hunter Douglas thermostats that uses 2 AA batteries for power and a SPST microswitch. Then go online and download the instructions on how to hook it up. It is a simple job that will require only the addition of a couple of batteries and some basic soldering work. Total cost $30 dollars.
donn is online now   Reply With Quote
Old 12-08-2011, 01:20 PM   #3
Dave, Judy & Dazey
3 Happy Campers's Avatar
I agree with donn above.
I installed a no name Walmart digital in each of my last three campers. Takes longer to open the factory packaging than to install. All your wiring is already in the wall. On the last one I don't think I paid $30.
Your dealer already knows what this will cost. Not sure why they couldn't quote you.
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 12-08-2011, 01:37 PM   #4
thermo
Thx to both for very much appreciated responses. Will follow your suggestions.
Old 12-08-2011, 03:17 PM   #5
Here is a link from another post on this subject
Hunter Thermostat
Old 12-10-2011, 02:51 PM   #6
I installed a Honeywell digital stat. The installation was very simple, and it controls the AC perfectly. BUT, it won't control my heat!! When I turn the switch to "HEAT" on the stat, the AC unit still kicks on & off.
HomeGrown is offline   Reply With Quote
Old 12-10-2011, 03:18 PM   #7
Go back and recheck your wiring job. There are several wiring schematics and you may have to try a different one to make things work as intended.
Old 12-25-2011, 03:58 PM   #8
I have just replaced my current programmable rite-temp digital thermostat with a Hunter non-programmable thermostat I purchased at Wal-Mart. See this link Walmart.com: Hunter Heat/Cool Just Right Digital Thermostat: Heating, Cooling, & Air Quality.
(Just did this as I thought my current one that I have had for a couple of years was causing my furnace heating problem ... and it was not)
Was an extremely easy install and this non-programmable thermostat is an easy thermostat for my wife to operate.
(I had purchased a Dometic Digital thermostat but had to resell in on ebay as I was unable to use it unless I did a circuit board change on my AC.)
OREGONCAMPER
2008 Rockwood 8317SS - 2010 F150
2012 Camping Days: 36
2011 50 2010 61
OregonCamper's Pics click here
OregonCamper is offline   Reply With Quote
Old 01-11-2012, 11:44 AM   #9
Someday have to find all the stuff for mine. I used a 12 volt rocker switch from napa. Mounted it on the wall. No toggle switch at all. Also use a Hunter. I have a Honeywell and got lucky to have an odd one.
USE A 42999B Hunter.
Portagie1968 is offline   Reply With Quote
Old 01-11-2012, 02:50 PM   #10
Agree with oregon camper
I have also replaced the analog thermostat with the Hunter. Very simple to install, small micro switch can be purchased from Radio Shack for low/high speed fan. The mod can be downloaded for the Hunter. The price from Wally World or Lowe's is around $20.00.
The analog thermostat has a +/- of 6° swing, where the digital has a 1-1 1/2° swing for start and stop of AC and Furnace which is more precise.
Sid & HRH- Daisy the Boykin.
2011 ROCKWOOD 8285 WS
2005 F-150 SUPERCREW
SUPER GLIDE HITCH
DAISY BOYKIN is offline   Reply With Quote
» Online Users: 524
91 members and 433 guests
12vdzl, 4bnabird, Adony, Al Fresco, amxpress, Big Vic, Biscuit, blaisrv, bowshark, bozemancamper, Buffalohunter, campnqueen, Canuck_Doug, Char_n_Kath, cousin01, davidjb, daw592, DonG, donh, donn, Elidh, Emptypockets, f1100turbo, firedaniel, fx4roo, gandr96, gimp425, Gman88, gucci, herk7769, heytomgraywolf, honda1, hoovercab, Iggy, jacksum2, Jeep4Two, JJFerg, Joseph5410, kb4srn, ken0042, KKapa, KRS, Lumpty, mack63, Mad4sax, maggiek, mamentt, manvel, mike1329, milw156, mraynie, mtl roofer, NeilM108, newby, NO3putt, ohiobill, okdrifter, PrairieBoy, railstar, rburk015, rickthelen, RickV, RJHuser, rkswyo, RV Guy, Sahgie, Saratoga Camper, Sawdr73, sherdep, sideout1961, softwarejoe, sprayking, spurge1947, stevem4134, thewren, Timex, Tincup13, Titleguy, Top B, TopGobbler, troyt, ugeesta, venturetaz, Vette4trcr, wbdvt, Whiteknight, whj77372, will4u, wnytaxman, wvfireboss, Zama
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
