Old 05-07-2016, 03:24 AM   #1
Dimmer for led lights?
Has anyone retrofitted a dimmer switch to led lighting in their rv? I have a xlr380 amp I'd like to be able to dim reading lights above bed as well as the living room lights. I've found dimmer switches on ebay as well as through Google but would like to see if anyone has done it before I venture in and try this.
jb4xx is offline   Reply With Quote
Old 05-07-2016, 04:57 AM   #2
You should not post the same in two places.
Filthy Beast is offline   Reply With Quote
Old 05-07-2016, 05:34 AM   #3
fonzie's Avatar
Look at these threads for more info.....
https://www.google.ca/search?q=led+d...Fsv1-AG886jQAg
Fonzie
Old 05-08-2016, 01:36 AM   #4
Michael4017's Avatar
http://www.technorv.com/Wireless_Dim...ed-ws-01dc.htm
I installed this for my bathroom led light. Wireless and easy installation. Win/win
'16 Cherokee 274DBH
'16 F150 XLT Crew 3.5eco
Mike
2016 Cherokee Limited 274DBH
2016 Ford F-150
Michael4017 is offline   Reply With Quote
Old 05-08-2016, 10:11 AM   #5
Thanks for the constructive reply filthy beast.
I did search for threads on led dimmer. I had hoped someone would say this will work...so many different types of wiring. Are the lights in these campers individual grounded with hot wire only running to them? Seems like a lot of dimmer require two wire install
Old 05-08-2016, 10:31 AM   #6
tahoe1840's Avatar
led dimmer
A dimmer for an LED light has to be specifically built for LEDs. You cannot use a standard incandescent light dimmer switch. They will not work.
tahoe1840 is offline   Reply With Quote
Old 05-08-2016, 12:46 PM   #7
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
Dim-lit!
LoL. I have a couple of dimmers that I added. Cheapo from eBay or Amazon, as I added them as I needed them. All 3 are the RF type, not infra-red, as IR needs line of sight. I got the kind with memory. I put the receiver either inside the fixture itself, or behind, in the wall or ceiling. Put the fob controller where I need to use it. That way, just the lights that needed dimming while on a common lighting circuit can be dimmed. One is just a dimmer with no remote, hard wired. added a switch into my bedroom wall instead of reaching 1/2 way across the bed every time I entered the bedroom. I will change that to a wireless someday, so I don't have to get out of bed to turn off the lights! Plus, that would have saved me fishing a wire thru the ceiling and down the wall.
Ps. I used one of those 12.00 mini usb cameras connected to my smart phone and taped to the fish tape to get the wires in place. Used it to wire the remote for my fantastic fan as well. Those things are awesome, and cheap! I got the one with about 20' of wire.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14
2001 Ford F-250 7.3
A Loving wife and Mason the always dirty dog!
Paulie1138 is offline   Reply With Quote
led, light
