Old 06-18-2019, 07:12 PM   #1
Dinette storage modifications?
New Wolf Pup has very little clothing storage. Want to put drawers in under dinette benches...anyone have any links/info to share?
Haelles is offline   Reply With Quote
Old 06-19-2019, 11:01 AM   #2
Not the same RV, but the same issue.
Here's the drawer I built under the dinette seat.
Bama's Rambling Mods
Gotta go campin!
Old 06-19-2019, 11:42 AM   #3
Kasual Kamper
The MicroLites that have slides have drawers under the dinette seat. Perhaps you can order parts from Forest River.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 06-19-2019, 04:27 PM   #4
We went the other way: We had drawers under the dinettes, but they wasted about half of the usable space:
The drawer face became a flip-down door:
The support plywood was screwed to the frame. It was removed, then I drilled a couple of finger holes to make it easy to lift:
Then we had access via the door, and for larger items or stuff way back under the seat, we could pull the cushion and panel.
However, all of that is now gone, replaced with:
and I'm working on storage boxes behind and below...
2016 Sunseeker 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
Old 06-20-2019, 09:38 AM   #5
Yes, the camper does not have any closet and there are 4 of us, so I think we need the drawers for clothing.
Old 06-20-2019, 04:13 PM   #6
If the space under the benches is clear, you can install drawers. Check first, sometimes things like water tanks or furnaces/water heaters are located in these areas.
Let us know what you find.
Old 06-21-2019, 12:35 PM   #7
Looks like you replied in my profile comments, rather than to this thread:
-----------Start Comment----------
Yesterday 02:52 PM
Haelles
Yes, they are clear for sure....you can open from top, but that’s a pain to get clothing. If anyone has any plans or tips or suggestions as to where to buy drawers already on a track.....please!
-----------End Comment----------
Yea, we understand the access issues - it's a bit of a pain to get to.
One mod we made early on was to change part of the pantry/wardrobe for this very reason. We didn't have enough drawer space, but we had wardrobe space that we'd never use. We don't hang clothes on hanger in the motorhome - everything is folded and stored.
Thus, I built a shelf and two drawers to the wardrobe:
Pertaining to your question/statement, drawers are generally designed for specific spaces. Subsequently, I'm not sure you'd find ready-made drawers with the parameters you need, such as depth, width, height, drawer face style & color, drawer carcass material, etc.
You might shop the furniture stores or general merchandise stores for a cabinet that contains drawers/slides similar to your needs, then adapt them to your dinette bases.
Beyond that, it would be a cabinet shop* or a friend that has some woodworking skills and equipment (and time/desire) to help. Otherwise, I'm out of suggestions.
* Good luck with cabinet shops - every one I tried to work with balked at the idea of working on an RV, and I can understand that. However, you might find a business that's in need of the work.
Old 06-25-2019, 04:06 PM   #8
What did you do with the old Dinette benches?
Pflugerville, TX
2021 Chaparral 360 IBL
2012 Ford F250 Super Duty 4x4 tow vehicle
RV there yet!
Tim966 is offline   Reply With Quote
Old 01-26-2020, 09:11 PM   #9
I just realized Tim966 asked me a question but I didn't see it until now. Sorry.
The benches are setting in the barn, awaiting disassembly. I'm planning on cutting down one of the end plates as they have the drawer faces that I had converted to doors, as you see in my second and third images.
Access to the water heater bypass valves is currently provided by removing the bottom drawer of the pantry/wardrobe, or at least disengaging the slide latches and extending the drawer a bit more. There's a blank-out panel below the drawer, where having a door would make it much easier.
I'm not sure anyone would want them:
but they might be of some value to someone. They'd cost a bundle to ship, however.
We still have the original cushions, but I've used the plywood panels that were supporting the bottom cushions for other projects.
Old 02-08-2020, 02:55 PM   #10
That is the theater seat I put in my Forester. Will miss it when I trade it in.
AbdRahim is offline   Reply With Quote
cat, modifications, storage
