Old 03-15-2012, 06:38 PM   #1
LKicklight's Avatar
Dinnet Slideout
Need to add an electrical outlet on the wall of our 270RET Crusader. The Dinnet Slide also houses the refrig. so there is a 110AC outlet inside the vent door that is actually attached to the inside of the wall where I need to have an outlet for 110V. The only thing we will plug into this outlet is a make up mirror and maybe a small lamp. Is there any problems with tapping into that same electrical outlet for the refrig.?
LKicklight is offline   Reply With Quote
Old 03-15-2012, 08:22 PM   #2
TURBS's Avatar
fridge in a/c mode draws between 5 and 8 amps.
on a 15 amp circuit you obviously know you have 10 to 7 amps left .
Old 03-15-2012, 10:30 PM   #3
caper's Avatar
You need to know if anything else is already on the same circuit as the fridge.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
