Old 11-06-2014, 08:02 PM   #11
Swift2
Swift 2's Avatar
I use an app on my iPhone called sat finder. I can see if there's obstructions trees etc. and exactly where the satellite is. It usually takes me 10 to15 minutes to set up my antenna once I have all my equipment hooked up.
Swift 2 is offline   Reply With Quote
Old 11-06-2014, 09:20 PM   #12
Mr. Dan's Avatar
Originally Posted by wowzer View Post
I don't understand the frustration with aligning the hd dish from directv. It takes me 20 min(not trying to be a bragert?). I use a signal meter. Get elevation and tilt from the zip code and just rotate the dish till high pitch on meter.
... and the first time you took your antenna out of the box and assembled and mounted it, it only took you 20 min to get a good signal?
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 12-12-2014, 08:18 AM   #13
When we tried putting the zip code in when we were using our Directv it wouldn't stay so when mu husband called them they said they had to change our zip....when we got home we had to call them to change it back.
Pleasantsurroundings is offline   Reply With Quote
Old 12-12-2014, 08:44 AM   #14
Mr. Dan's Avatar
I'm not sure what you mean by "it wouldn't stay". As I remember, I entered my park ZIP code to get tilt, azimuth, elevation settings to adjust my antenna. After that it didn't matter. Maybe that's because I was only 250 miles from home.
Thanks for the post. I assumed I had killed the thread!
Sent (I think)
Old 12-12-2014, 09:07 AM   #15
Directv setuo
Just asked my husband about the zip code thing and he said in order to get the local channels that is why they had to change it.
Old 12-12-2014, 11:26 AM   #16
Mr. Dan's Avatar
Direct TV
I got home locals which is what I wanted. I used my phone apps for weather, etc.
Sent (I think)
Old 12-12-2014, 11:52 AM   #17
Hi wowzer,
Please provide us less technical folks with more details, model/source for signal meter? is the a smart phone app for the elv/tilt by zipcode?
Thank you,
Wanderer
2008 Cardinal 30RK fiver.
2009 Chevrolet 2500HD DuroMax
2009- 42 days; 2010-40 days, 2011- 40 days. 2012- 30 days,
2013- 14 days, 2014- 21 days, 2015- 42 days
2016-17 days, 2017-zero days
Wanderer is offline   Reply With Quote
Old 12-12-2014, 04:36 PM   #18
Swift2
Swift 2's Avatar
The smart phone app is Sat Finder. Works great for me.
Old 12-12-2014, 06:36 PM   #19
Mr. Dan's Avatar
Originally Posted by Wanderer View Post
Hi wowzer,
Thank you,
Wanderer
I'm not wowzer but I think I can help.
I use the iPhone app "SatFinder Lite" MERELY/ONLY to determine if my antenna has a clear path to the 3 satellites (no trees, no RVs, no neighbor, no ice cream parlor in my way). Then when I run through the DIRECTV onscreen setup procedure, I enter my ZIP code to get tilt, azimuth, elevation settings. Then I set the antenna's tilt, then the elevation then I point the antenna roughly in the direction SatFinder Lite shows the satellite(s). Then I set my TV to broadcast sound through my radio/DVD player and turn on my outside speakers. Then I set the onscreen program to "beep" when I get a signal and turn my antenna slowly left to right to left until I get a fast pulse beep and I'm done.
BTW, I don't use a signal meter other than the DIRECTV configuration program.
Old 12-12-2014, 07:24 PM   #20
As a suggestion;
I use a baby monitor to set up my portable sat dish. I plug the base in by the TV and put the remote on my belt. That way no one gets bothered by the noise.
jwedell is offline   Reply With Quote
