Old 09-07-2015, 08:00 PM   #11
textman's Avatar
Talking
Originally Posted by rsdata View Post
highly recommend the HD tripod setup from
Heavy-Duty Combo Package for RV TV Satellite Dish
I can have my HD DirecTV receiver hooked up and ready to watch in 10 minutes. If you follow their instructions, you can hit the sat link the first time every time with no tweaking necessary. Couple this with the Dishpointer APP for your smartphone which will show you the spot through tree cover to set the dish and you are all set.
Getting the tripod perfectly level is the hard part of setting up your dish, and their tripod makes that very easy to do.
Very happy with my setup and very happy with TV4RV.com personal service answering my pre-sale questions.
Ditto to this setup! Only way to get it right the first time...
2012 Cedar Creek 36B4
2007 Ford F-350 Dually Crew Cab 6.0 Studded w/EGR Delete
Loving Life
textman is offline   Reply With Quote
Old 09-07-2015, 11:16 PM   #12
A lot depends on how your rig is wired. If you have a cable input jack in the electrical compartment that goes to a switchbox then you can use that cable for your DTV antenna if it's RG6 cable. Disconnect the cable from the switchbox and run it to the DTV receiver or the DTV SWM power supply box. You'll still have the problem of getting the HDMI signal from the DTV box to the TV.
In my Georgetown, the "cable input" cable from the rear compartment goes to the common side of an A/B switch One side of the switch goes to the FR supplied switchbox (antenna, cable, aux), the other to the SWM power brick. When I'm hooked up to a park's cable system, the signal from the cable is fed to the switchbox then to the TVs in the unit. When I'm using the satellite receiver, the A/B switch connects the cable to the SWM power supply which then connects to the receiver.
The HDMI signal from the DTV receiver is fed to an ActionTec HDMI over wifi transmitter which feeds two receivers, one for each TV. I am limited to watching the same program on both TVs at the same time but since they're only 15' apart, there'd be audio interference between them if they were playing different programs.
Phil
pmsherman is offline   Reply With Quote
satellite
