Old 09-06-2015, 01:03 PM   #1
Direct TV satellite install
I have direct TV at home and want a tripod set up for our 2012 Berkshire. Once I get the tripod set up how do I hook it up to my internal system?
I've heard a few suggestions but they involve running a line through the window set up.
Isn't there a jack that I can access from the outside??
Any help is appreciated.
billy2458 is offline   Reply With Quote
Old 09-06-2015, 01:19 PM   #2
My has a satellite jack on the outside of mine. Not that I had to use it. Have a roof mounted dish.
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
cfiowa is offline   Reply With Quote
Old 09-06-2015, 01:22 PM   #3
where are the jacks located?
Old 09-06-2015, 01:45 PM   #4
nomad297's Avatar
The satellite connection is almost always right next to, above or below the cable connection.
Bruce
nomad297 is online now   Reply With Quote
Old 09-07-2015, 11:49 AM   #5
rsdata's Avatar
highly recommend the HD tripod setup from
Heavy-Duty Combo Package for RV TV Satellite Dish
I can have my HD DirecTV receiver hooked up and ready to watch in 10 minutes. If you follow their instructions, you can hit the sat link the first time every time with no tweaking necessary. Couple this with the Dishpointer APP for your smartphone which will show you the spot through tree cover to set the dish and you are all set.
Getting the tripod perfectly level is the hard part of setting up your dish, and their tripod makes that very easy to do.
Very happy with my setup and very happy with TV4RV.com personal service answering my pre-sale questions.
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 09-07-2015, 12:21 PM   #6
Don't use the cable jack if you have an over the air tv amplifier...you need an unamped line to work with DTV. You might be OK if you have both cable and sat jacks.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 09-07-2015, 02:59 PM   #7
I had the roof mounted dome on my last RV, now I have the tripod and doom. I don't care if they park me under a tree, it's easy to move and fine reception.
On the street side of my Cherokee I have two inlets, one for cable and one for satellite and the same inside on my entertainment center.
Las Cruces is offline   Reply With Quote
Old 09-07-2015, 03:35 PM   #8
redcloud1's Avatar
If you don't have a separate satellite hookup you'll have to go in through the window.
redcloud1 is offline   Reply With Quote
Old 09-07-2015, 04:52 PM   #9
Some like mine, have a park cable and satellite hook If you use park/antenna, need to turn off booster at internal hook up
wrt111 is offline   Reply With Quote
Old 09-07-2015, 06:30 PM   #10
I use this on mine.
http://www.amazon.com/gp/aw/d/B0018B...9CYV8N86CTN19X
Put it inside the wall just before the antenna amp splitter, and run a seperate wall jack for the satellite box, then hdmi cable from the box to tv.
If im at a place that has cable, then it works like it would normally. No cable, then i hook up my dish to the cable input on the trailer and use that.
2017 Freedom Express 271bl
2013 Silverado Z71
TimNJTA is offline   Reply With Quote
satellite
