Old 06-23-2012, 08:07 AM   #1
DIY levelling block - Instructions Desired
Good day,
I called Bal company and they said their leveller will not work for my 12in tires without adding wooden blocks to them. So......
I went to the hardware store and bought a 1x6x8 pressure treated board and some screws.
I read a post recently where someone showed a picture of what they built. I could not find it today. Would someone mind posting a picture with some instructions on how to make it. Im more intersted in the lengths of the cuts to make it a three tierd platform. Im afraid I will make the each platform either too short or too long.
Thanks and I hope this makes sense
xavier
2012 Forest River 206ltd
xavier is offline   Reply With Quote
Old 06-25-2012, 10:46 AM   #2
Ok so with no replies and no woodworking experience I gave it a go
Heres what I made. 3 lengths 30 in, 20 in, 10 in, screwed together with brass wood screws and 45 degree angle edges for the tires to roll onto it easier. I finished the top and sides with some deck stain I had in the garage.
Hope it works well.
xavier
Old 06-25-2012, 11:29 AM   #3
MikeInColo's Avatar
I had a pair of leveling blocks very similar to this (they weren't coated with anything--just pressure treated wood). One just split down the middle recently and I'm debating on building another pair similar to yours (thanks for providing your specs) or buying the Lynx Level block system. I have a class c with "duallies" in the back and wasn't comfortable with the single level block.
Hopefully, you'll get a lot of use out of those levelers!
MikeInColo is offline   Reply With Quote
Old 06-25-2012, 11:38 AM   #4
prof_fate's Avatar
I got a set of those 'lego' type blocks for leveling the wheels and you can build up a tiered thing like you've done. the plastic hasn't split or cracked, is light weight and easy to clean and easy to store.
So far one 'kit' has been enough but I'm tempted to get a second one.
under the tires on the ground I put some chocks, then X-chocks between the wheels on both sides, then 4x4 PT blocks under the jacks/tounge (and they work for chocks in a pinch too)
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 07-02-2012, 12:47 AM   #5
I built a set similar to xavier's but decided to not attach the boards to each other. I made a jig and used it to drill two matching 1" holes in the shorter boards and a 1/2 board thickness hole in the longest one. A 1" dowel was cut into pieces that match the thickness of the boards and I can now easily change the height of the boards under each wheel.
When I use the blocks, I set them up for the appropriate heights, always using the longest boards, and slide them up against all of tires. All of the wheels end up at the tall end of the blocks at the same time.
Phil
pmsherman is offline   Reply With Quote
Old 07-02-2012, 10:00 AM   #6
MikeInColo's Avatar
That is a great idea pmsherman. I'm wondering if you sealed/painted the boards?
Old 07-02-2012, 11:04 AM   #7
IT Guru
Send a message via AIM to jsilvius Send a message via Skype™ to jsilvius
I've got 2 sets of Lynx, and I've got 4 2x6x36 "ramps" that I can stack if I really need them. I left the 2x6 ramps separated so I could use them.
good luck with your creation Xavier
2006 Flagstaff 831FKSS
2005 Dodge Ram 2500 SLT 5.9L Turbo Diesel Quad Cab
1 - DH (me); 1 - DW (Tee); 1 - DS (Jarod, 12)
Nights Camping: 2010 - 15; 2011 - 7; 2012 - 9
jsilvius is offline   Reply With Quote
Old 07-02-2012, 08:31 PM   #8
I used pressure treated 2" boards and didn't do anything to finish them. This wood is designed to be in contact with the ground and if there's any drainage where you're parked, won't be sitting in a puddle.
Phil
Old 07-03-2012, 05:25 AM   #9
great white's Avatar
4 packs of lynx levelers for my tandem axle.
I'll never go back to wooden blocks again....
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
Old 07-03-2012, 10:01 AM   #10
TURBS's Avatar
I'm with you!
Old 07-03-2012, 05:43 PM   #11
update
So I just got back from my 5 nights in NH. The levelling ramp worked great. Here are some pics!
ID:	16075   Click image for larger version
ID:	16076   Click image for larger version
ID:	16077   Click image for larger version
ID:	16078   Click image for larger version
xavier
Old 07-10-2012, 07:11 PM   #12
Paul & Sheri
pwb01's Avatar
Phil
I have exactely the same thing. I have short dowels on the bottom piece too to hold it from slipping when I back on.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 07-10-2012, 07:34 PM   #13
Dennis and Julie's Avatar
We have 3 packs and no never go back to wood again.
Dennis and Julie
2018 Wildcat 28SGX
2013 Chevy Silverado 2500HD
2012 Chevy Silverado 2500HD
Dennis and Julie is offline   Reply With Quote
Old 07-11-2012, 09:06 AM   #14
Road-King's Avatar
Never say never... There is a CG in our area that has blacktop sites and has banned plastic blocks on the ground. I guess they were cutting into the blacktop on hot days. So I use some pressure treated 2x12x12's to go under the plastic blocks...
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 07-11-2012, 10:13 AM   #15
trudinator's Avatar
Originally Posted by f1100turbo View Post
I'm with you!
x3. We have 3 sets. Much easier to zip them in their nylon carrying case and store them in outside storage then to have to find a place to store huge slabs of wood.
2012 Rockwood 8293RKSS
2006 Dodge Ram 2500 5.9L Cummins Turbodiesel 4x4; 2012 Ford Escape 4x4. 3 very pampered cats.
Days camped: 2011: 61; 2012: 66 Days; 2013: 69;2014: 68 2015: 90 Days camped 2016: 34
trudinator is offline   Reply With Quote
