Old 02-19-2015, 06:41 PM   #11
Goose killer's Avatar
Bauer
2015 Nights Camped 32
2014 Nights Camped 21
2013 Chevy Silverado 2500 HD Duramax
2014 Cherokee 304 BH
Goose killer is offline   Reply With Quote
Old 03-01-2015, 03:16 PM   #12
BigTJohn's Avatar
RVLock is great. I have had the same one on 3 different trailers. 1st on a Thor Dutchmen then moved it to my Grey Wolf. It took a little bit of fussing to get it to function exactly right on both of the TTs but it worked great. Moved it to my 2014 Columbus and still love it. I got the remote keypad, located in the propane door and two remotes. All are great, batts last a long time as in batteries in the lock itself every year, and in the remotes every two years.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 03-01-2015, 05:16 PM   #13
Phat Phrog Stunt Crew
elind's Avatar
I've had the "RV Lock" since August and been totally pleased.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 03-01-2015, 05:34 PM   #14
Old Timer
Crossroads Cruiser I used to have had a factory installed keyless entry lock which worked great, but of course was "hard wired". Don't recall the mfg. Liking that so well, I installed a Bauer on my new Wildcat 275CKX. First time out this weekend I had to reprogram my code. Seems to be a common problem with this make. Should have probably spent a little more and got the Mobile Outfitters or RV Lock (are they the same?). Anyway when they are working they are very convenient. Just keep the key handy somewhere.
kentnjudy is offline   Reply With Quote
Old 03-01-2015, 06:05 PM   #15
Hi I have been looking at Bauer Locks it is direct replacement for a travel trailer door latch. This an link to there web site. Bauer Products - Bauer Products Videos
Hope this helps Tim
TimVWulp is offline   Reply With Quote
Old 03-01-2015, 06:15 PM   #16
oops lost the live link here is an an other try
Hope this helps Tim
Old 03-05-2015, 05:21 PM   #17
Broke and happy
bobfa's Avatar
Bauer locks are good and their waranty and customer support is thumbs up. They replaced a 8 month old unit I purchased new on ebay. The lock I bought were supposedly their rejects that got resold by enterprising ebayer for discount.
bobfa is offline   Reply With Quote
Old 03-06-2015, 11:18 AM   #18
jmgllt's Avatar
Very good info.
jmgllt is offline   Reply With Quote
Old 03-06-2015, 11:38 AM   #19
SKnight's Avatar
I have the Bauer keyless lock and I'm mixed. It works well, but tends to default back to the factory code randomly.
Edit to add- I noticed that when the batteries are brand new it's no issue, it will work for a long time after the default starts happening so maybe once the batteries have a little use the voltage gets low enough that it defaults, but not so much it quits working. I have considered wiring in a direct feed from the house batteries.
Their customer service is great, my original had an issue, my dealer couldn't do anything with it so I called Bauer directly, they sent one second day air with a label to return the original. No fuss, no issue.
Old 03-09-2015, 09:01 AM   #20
I just installed the lock with remote from rvlock.com. Easy install, but I had a difficult time changing the default lock/unlock code. Tried same setup the next day, changed easily the first time. The lock can also be used with supplied keys. The lock mechanism seems more substantial than the OEM door hardware.
I HATE carrying keys.
Gordog is offline   Reply With Quote
