Old 09-23-2012, 06:36 PM   #1
stepside's Avatar
Dometic LCD Thermostat - Honeywell upgrade?
Hello All,
No, not another thread on how to install a Honeywell thermostat on a basic setup, I have a situation here! I've installed digital thermostats on our last 2 TT's, but this one through me for loop.
2011 FR Surveyor SP275
Dometic LCD Thermostat:
The thermostat has 3 wires, red 12+, white 12-, and blue wire marked common
using a test light, and crossing the red and white wires, they have constant power regardless if the system is dormant or a system is running.
I traced the wires to the A/C unit where the control box is at. You can see the red/white/blue wires in the brown loom on the left of the photo. At the upper -middle of the pic, you can see a second brown loom w/ red/white wires: they go back to the furnace.
The wiring diagram for the control unit is located on the lid:
Is there anyway to replace the dometic LCD thermostat? I just can't believe it doesn't show the current temp!!!!
Any advice is appreciated.
2006 Nissan Frontier Crew
2011 Surveyor SP275
stepside is offline   Reply With Quote
Old 09-23-2012, 08:12 PM   #2
In the manual it states:
"TO display the Inside Temperature, the Single Zone LCD thermostat must be in the Off Mode. Press either the “+” or “” button to display the Inside Temperature."
It does not have a continous inside temp display, but that would be a nice feature. I replaced the stock T-stat in our previous 2 campers with a Hunter Programmable and I was very happy with the mod.
Old 09-23-2012, 08:56 PM   #3
stepside's Avatar
thanks for letting me know that it atleast can display the current temp.
have you replaced a dometic LCD stat before, like mine?
2011 Surveyor SP275
Old 09-23-2012, 09:35 PM   #4
Road-King's Avatar
Found some info for you to read. Looks like this mod is a no go for the type of thermostat...
Help wiring new Hunter stat. [Archive] - Keystone RV Forums
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 09-24-2012, 09:33 AM   #5
No, sorry, neither of my previous campers had a Dometic T-stat.
