Old 04-12-2016, 02:48 PM   #1
TURBS's Avatar
Dometic snap disk thermostat
Does anyone know what the open / close temp. Is on the snap disk thermostat that dometic uses for the external cooling fan on the dometic refrigerators? [emoji848]
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 04-13-2016, 06:53 AM   #2
TURBS's Avatar
No one has checked?
2008 2500hd Duramax
2015 Columbus 320RS
Old 04-13-2016, 07:15 AM   #3
Who Dares, Wins
doc73's Avatar
I do not even know what you just said! [emoji12]
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 04-13-2016, 07:18 AM   #4
TURBS's Avatar
Dometic uses a snap disk thermostat to turn the exterior fridge cooling fan.
I'm wondering what the open / close temp is.
2008 2500hd Duramax
2015 Columbus 320RS
Old 04-13-2016, 07:21 AM   #5
DDC
DDC's Avatar
If my translation is correct he is asking if anyone knows the pre-set on and off temperatures of the cooling fan thermostat on the domestic fridge.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 04-13-2016, 07:22 AM   #6
TURBS's Avatar
You'd be correct!
Old 04-13-2016, 07:27 AM   #7
Who Dares, Wins
doc73's Avatar
I was being a smart butt.. I did somewhat gather his technogeek speak.
2015 Chevy HD D-Max
Old 04-13-2016, 09:34 AM   #8
patchman's Avatar
If the sample picture is the same one as on the refrigerator then the open temperature setting is 90F and the close temperature setting is 110F. These settings are for a model 610044 controller and the info was found on climatedoctors.com in the event this was not the correct snap disk controller you speak of.
patchman is offline   Reply With Quote
Old 04-13-2016, 09:46 AM   #9
TURBS's Avatar
Picture posted is just for reference.
2008 2500hd Duramax
2015 Columbus 320RS
Old 04-13-2016, 10:18 AM   #10
patchman's Avatar
Sorry bout that. Not near my 320 right now but I suspect if you go to that web site with your controller model number you should hopefully find your upper and lower limits, they had a lot of different controllers listed there.
Old 04-13-2016, 02:58 PM   #11
CDR USN Ret
The switch will be labeled (or, as on some, it will be embossed on the body somewhere), with markings similar to those in the picture. The F means Fahrenheit, the 110 means it will close (since this is a "normally open" switch) @ 110 degrees F. The 20 means it will reopen at 110-20=90 degrees.
You can replace it with any manufacturer's, similarly configured and rated switch.
Best place to get one is at a appliance repair parts, or HVACR supply (Google is your friend).
(HVACR contractor/instructor, 20 yrs)
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
DSQR is offline   Reply With Quote
Old 04-13-2016, 03:01 PM   #12
TURBS's Avatar
Problem is I can't reach it nor read it or I'd have done that.
Maybe I'll try a extension mirror.
2008 2500hd Duramax
2015 Columbus 320RS
Old 04-14-2016, 12:51 PM   #13
Turbs... I just ordered one from the dealer. It will be a week or so before I have a chance to go pick it up. I will post the specs when I get it
dragon-roo is offline   Reply With Quote
Old 04-14-2016, 01:34 PM   #14
TURBS's Avatar
Thanks.
2008 2500hd Duramax
2015 Columbus 320RS
Old 05-04-2016, 01:38 PM   #15
patchman's Avatar
Turbs, did dragon-roo ever get back to you on what the thermistor disk specs were?
Dianne & Dave
2013 Columbus 320
2014 Ram 3500 HD srw
Old 05-04-2016, 01:40 PM   #16
TURBS's Avatar
Negative.
Old 05-04-2016, 01:53 PM   #17
Sorry guys... I'm still waiting on it. I got the other things that I ordered from my dealer but the switch was on backorder
I'm glad to take one for the team and find out what the specs are... just wish the darn thing would show up. I want to install it and my fans so I can get the last piece of wood put in the storage cubby I put above the fridge.
Once we know the specs, you can get them many other places for about half of the price.
Early 2016 Rockwood Roo 19
Old 05-04-2016, 02:09 PM   #18
TURBS's Avatar
Yeah, I just need to know what the on / off temps are as a guide for setting my temp controllers.
No biggie I'm up and running.
Let us know.
Old 05-04-2016, 02:19 PM   #19
We run the fans whenever the frig is turned on. 2 in the rear across the tubing and fins and 2 inside the frig. Keeping the back (fins and tubing) cool is the key to making the cooling unit as efficient as possible.
dometic, thermostat
