Old 06-27-2016, 11:36 AM   #1
PHS79's Avatar
Dometic T-stat replacement??
I have a dometic T-stat in our camper, like this one only ours doesn't have the "heat strip" option on it.
I would like to replace it with a T-stat that will display the current inside temp all the time. I had an extra house T-stat sitting around but after doing some reading I found that will not work with this system.
Any input to a T-stat that will display the current inside temp at all times and work with the dometic 3 wire setup?
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 06-28-2016, 09:26 AM   #2
Head Rambler
I don't know of a compatible unit to replace that particular T-Stat. It's a bummer too, because we're stuck with either buying replacement units from the mfg. or changing out the t-stat and the control box, which also requires pulling new t-stat wire.
It would be nice if someone had a digital plug in replacement for those units.
Gotta go campin!
Old 06-28-2016, 10:51 AM   #3
An easier solution is to just get a small battery powered thermometer and some 3M command strips and stick it right next to the thermostat.
Here's one from Home Depot. Would probably fit nicely on a small command hook.
Iwritecode is offline   Reply With Quote
Old 06-28-2016, 11:10 AM   #4
Who Dares, Wins
doc73's Avatar
I just bought one from the Home Disaster and did it that way. Much cheaper.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 06-28-2016, 09:27 PM   #5
PHS79's Avatar
Thanks for the input! What actually brought on the idea of replacing the thermostat was this past week while on a trip to Mt. Rushmore our A/C started to shut down on us on our last day and I have no idea why. Here is the story on that A/C shutting off Since I am not sure where the issue is, if it is the thermostat or the A/C unit itself, and I had been wanting to be able to have the inside temp I figured why not just install a new thermostat that will display the temp and also get rid of a possibly problematic thermostat all in one shot.
If anyone has any input on my A/C problem, please feel free to let me know!
nights camped:
dometic, replacement
