Old 08-07-2014, 09:12 PM   #11
Plain Old Member
I've found that even on D1 it's hit and miss. Either way, I miss the old style Dometics. Would rather have a Coleman Mach right now.
Sent by ME
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 08-07-2014, 10:05 PM   #12
NELA
Weezer's Avatar
That's odd to see John. We have the Coleman Mach stats in ours.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 08-08-2014, 05:33 AM   #13
Plain Old Member
Weezer, how are the newer Coleman t-stats set up. I hadn't looked at the latest ones, but our 2012 tiffin had 2 Coleman's and the units / t-stats worked way better than the dometic.
Sent by ME
Old 08-08-2014, 09:13 AM   #14
NELA
Weezer's Avatar
I'll take a close up pic of them today and post it here for ya.
That way you can see all the pretty bells and whistles.
Old 08-08-2014, 02:58 PM   #15
DougP47's Avatar
Sent by ME
Thanks to al for your help. Not sure about Coleman but mine is working much better now. I changed to D1 stat is working within 1 deg now. No more on till i see icicles before it turns off or hot zones before the ac turns back on. After unit is running and cools tt down. On restart thw low speed fan comes on, no high speed fan needed. Thanks Doug
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
DougP47 is offline   Reply With Quote
Old 08-08-2014, 08:25 PM   #16
Infractee
Originally Posted by RJHuser View Post
Talked with the Dometic AC expert at breakfast this morning.
To change the thermostat temperature differential, do the following:
Press the "OFF" button to shut the thermostat off
Press AND Hold "MODE" and "+" until display shows "D2" or "D1"
Press "+" or "-" to display "D1"
According to the Dometic guy, the default setting is "D2" which is +/- 2* differential, "D1" is +/- 1* differential.
Rick
Thank you Rick! I will try this on our next trip out! Hopefully the dealer will have it back to me while I still need the A/C... LOL
RhoZeta is offline   Reply With Quote
Old 08-09-2014, 08:03 PM   #17
NELA
Weezer's Avatar
As promised BigJohnD:
Name:	coleman mach 2.JPG
ID:	60020   Click image for larger version
Name:	coleman mach3.JPG
Old 08-10-2014, 06:08 AM   #18
Plain Old Member
Thanks Weezer. The digital one is the same type we had in our Tiffin, except they had the heat pump selection also.
Sent by ME
Old 08-11-2014, 09:57 PM   #19
So I have the analog version of the Coleman-Mach. Is it a simple replacement with the digital version?
2015 Keystone Raptor 425TS full body paint
TV 2015 RAM 3500 MC 4x4 DRW w/ AC69RC HD Trans
Pullrite Superglide 2300 24k w/ OE adapter 25k
cobiker is offline   Reply With Quote
Old 08-12-2014, 07:12 AM   #20
Plain Old Member
Pretty much. I don't have the directions for the Mach t-stat conversion, but I know somebody on here does. A google search will always turn up something on both brands conversion to a digital. Only thing the digital won't do is multiple fan speeds, so you can either install a toggle to do so, or wire it for one speed or the other. In the case when we did that conversion several campers ago, it was high speed only.
Sent by ME
dometic, thermostat
