Old 08-04-2016, 05:33 PM   #1
TsnTexas's Avatar
Don't know if my fridge has a defroster
I can't tell from the manual whether this Dometic fridge has a defrosting strip or not. The model is a DM2652RBX. Anybody know where I might find out - I've done a search online as well, but without success. We do a lot of boondocking and I need to extend my battery life.
2016 Rockwood 2504s
2016 Chevy 2500HD
TsnTexas is offline   Reply With Quote
Old 08-04-2016, 05:45 PM   #2
Take the lower outside cover off and look for the wiring diagram. Look at the lower left corner. Compare it to the pic of mine (it's an LBK, not an RBK). Item "K" is the heater cable in parallel with my inside light. If you have a squiggly line like my "K" in parallel with your inside light, you've got the defrosting strip.
Name:	Fridge schematic 2.jpg
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
Old 08-05-2016, 08:43 AM   #3
TsnTexas's Avatar
Rockfordroo, I never thought about looking at the wiring schematic. But then again I wouldn't have known what exactly to look for until your response. Did you post something about how you disconnected your defroster in another discussion about it?
2016 Rockwood 2504s
2016 Chevy 2500HD
Old 08-05-2016, 08:58 AM   #4
All I did was clip the wire from inside the light cover and add 2 spade ends in case I wanted to re-connect it later. I put the cover back on and it has never given me any problems in the last year and a half.
2015 Forest River EVO 2850
2012 Dodge Ram 2500 6.7 Cummins
Yamaha 2k x 2 with parallel cable
EMS 30 PI portable w/ Edison plug
Nights Camped (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 08-05-2016, 03:13 PM   #5
TsnTexas's Avatar
I see on the diagram that I have the heat strip. Have taken off the light cover and see an extra wire down in the hole there behind the light. Appears the light housing is held on the wall by a plastic rivet - did you guys drill that out in order to access the wire?
2016 Rockwood 2504s
2016 Chevy 2500HD
Old 08-05-2016, 03:33 PM   #6
Isn't there an on/off switch in the top of the freezer or the fridge on the inside?
2003 GMC 2500 HD 8.1 & ALLISION TRANSMISSION
2000 SIERRA 30 ft FKSS
hondo is offline   Reply With Quote
Old 08-05-2016, 03:41 PM   #7
TsnTexas's Avatar
Unfortunately not, heard they used to have that, but I guess they are trying to save a few pennies. Wish there were!
2016 Rockwood 2504s
2016 Chevy 2500HD
Old 08-05-2016, 05:21 PM   #8
I just slipped a pair of needle nose pliers in there and pulled the wire up.
Old 08-05-2016, 08:48 PM   #9
I haven't done mine yet, but I've posted another forum member's step by step. Here it is again.
Old 08-06-2016, 07:30 AM   #10
TsnTexas's Avatar
Fantastic! Thanks for your help guys.
2016 Rockwood 2504s
2016 Chevy 2500HD
fridge
