Old 09-29-2016, 06:40 PM   #1
Don't Say It Can't Be Done
After alot of research, conversations with Graphic Companies regarding my faded Lexington Vinyl Decals..I made up my own mind. It's going to take time due to early morning time frame and no wind ti acvomplish, but I started tiday. Yep, painting my decals. Using gloss Fusion plastic /vinyl spray paint from Pep Boy's and Home Depot, it's a go. Results: Perfection. I'm doing all the black first, then onto the Cinnamon and Silver. Prepped with rubbing alcohol..yes, it removes all contanimates, residue, wax. Let dry. Masking and tapung, very time consuming, but hey, results are worth it. Dry time between coats? 20 minutes. How many coats? 3. Will post as I coimplementation sections over next few days. Cheers...oh, and saves ALOT of $$$$$.
ID:	121657   Click image for larger version
Mac964 is offline   Reply With Quote
Old 09-29-2016, 11:32 PM   #2
Iggy's Avatar
Nice Job!
You are the first I've heard of doing this.
Did you put a clear coat over it or it wasn't needed?
I helped you by flipping pictures.
ID:	121679   Click image for larger version
2012 Georgetown XL - 378TS
Old 09-29-2016, 11:44 PM   #3
NMWildcat's Avatar
Yep, first I've heard of anybody doing this So you are actually painting over the existing vinyl graphics without removing them first?
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 09-30-2016, 01:43 AM   #4
asquared's Avatar
Interesting concept. I would be interested to hear how this holds up over time.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is online now   Reply With Quote
Old 09-30-2016, 09:14 AM   #5
A big pat on the back for you. Great idea. I'm also interested in knowing if you painted over the existing decals or did you remove them before painting? Please share other photos as you continue.
Thurman is offline   Reply With Quote
Old 09-30-2016, 12:26 PM   #6
Nice job.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
Old 09-30-2016, 12:42 PM   #7
dea49's Avatar
Did you rough up or sand the original decals before painting or just used the alcohol?
2007 Rockwood UltraLite 2603
2006 F350 Lariat Crew Cab Super Duty 6.0 diesel 4X4
dea49 is offline   Reply With Quote
Old 09-30-2016, 02:24 PM   #8
Wow, just wow!!!! I would never have thought of just painting them.
brewjaz is offline   Reply With Quote
Old 09-30-2016, 04:24 PM   #9
Retired JSO's Avatar
I did my old fiver several years ago. I removed the old decals with a wall paper steamer and using striping tape outlined the original graphic. After taping and papering the area, used krylon spray in several matching colors which came out real good.
Retired JSO is offline   Reply With Quote
Old 09-30-2016, 04:57 PM   #10
Cyber Phrenologist
Radio's Avatar
Being really, really lazy and cheap, I colored in the cracks forming in my darkest decals with a black, oil based paint pen. The darkest, almost black decals are the only ones cracking and you don't notice it unless you are within arms reach of the trailer.
In a few years, I guess I'll paint over all of them. Not a bad idea...
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
