Old 01-17-2016, 12:16 PM   #11
There is a screen on the room side of the glass.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 01-17-2016, 01:01 PM   #12
banda's Avatar
Maybe I'm missing something, but doesn't the screen door prevent being able to pass anything through the exterior door window?
banda is offline   Reply With Quote
Old 01-17-2016, 07:03 PM   #13
Not sure what you are asking, air will pass thru just fine. That was the point of the install so we could get some airflow thru the bedroom while towing on hot days.
Dale & Karen
Old 01-23-2016, 07:52 AM   #14
The glass opens from the outside? How does that affect security? What's to stop a bad guy from sliding the window up then unlocking the door from the inside?
Mike
Mike Schultz
Mikeschultz85 is offline   Reply With Quote
Old 01-23-2016, 11:16 AM   #15
AKA: 'tiredTeacher
awellis3's Avatar
No. It opens and latches from the inside. Then the screen door is latched to the entry door (as always) before shutting the door.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 01-23-2016, 03:34 PM   #16
Thanks. That's what I would've figured. Somebody else said the screen is on the inside though. So the screen must raise to allow access to the glass?
Mike
Mike Schultz
Old 01-23-2016, 04:51 PM   #17
The window has its own screen, separate from the door. And it will open with the window if wanted. But it does not line up with the screen door opening.
Dale & Karen
door
