Old 07-17-2016, 02:51 PM   #1
Double Flooring
I have a 2014 MicroLite 21FBRS with water damaged flooring that has soft spots. Can I simply build a new floor on top of the existing floor, or should I pull up the existing floor and rebuild it? It is not a very large area. Gracias!
Hector517 is offline   Reply With Quote
Old 07-17-2016, 03:01 PM   #2
EVERYTHING that is on Top of the Floor must be removed,Outside walls,Inside walls,plumbing,elect,heat/AC ducts,are you ready for that amount of Work and $$$? Youroo!!
Old 07-17-2016, 03:15 PM   #3
What are you willing to accept in looks, feel, ridges in the floor, mismatched floor covering, etc.? That will give you your answer.
Cedar Creek Lake, Texas
2016 Wildwood Xlite 171 RBXL
2016 Ram 5.7L crewcab.
CedarCreekWoody is offline   Reply With Quote
Old 07-17-2016, 04:06 PM   #4
CANADA FROG RALLY 2017
B and B's Avatar
I am going to take a different stance. Can you get yet tea from under the trailer? Maybe attach larger pieces than the bad spot underneath, glue and brace in place. This might get you a trailer floor that is useable.
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
B and B is online now   Reply With Quote
Old 07-18-2016, 02:24 AM   #5
Double Flooring
A college professor told me that the secret to success is to surround yourself with people who are much smarter than you. Thanks, gentlemen for your comments. I think I will try to support my soft floor from below, rather than to build a solid floor from above. I will follow-up with my results.
Old 07-18-2016, 05:20 AM   #6
Hector517, please post Pic,s of this Endeavor! Youroo!!
Old 07-18-2016, 05:46 AM   #7
grumpy0374's Avatar
If you have water damage, and a soft floor area, just covering it, either from the top or bottom, will not get rid of the problem. Your still going to have bad/rotted wood under the "new" floor, and you still may have a leak that will rot the new covering.. If the soft area is still wet/damp when you cover it, you haven't acomplished anything...the rot will probably spread.
Grumpy
Steve & Cheryl + Charlie & Casey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
Camping trips this year so far...8
Days camping...75
grumpy0374 is offline   Reply With Quote
Old 07-18-2016, 01:20 PM   #8
Double Flooring
I accept everyone's comments. I have an autoimmune neuromuscular disease called myasthenia gravis that is weakening my legs. The unstable soft floor is hazardous to me. I just need a temporary fix until I can trade my wreck in for a newer, better RV. All the RV brochures promise beautiful, high quality units at a nice price. But, I have learned that beauty is only skin deep. I will upgrade and improve my new RV right off the lot. My physical disability makes it difficult for me to make repairs. Until then, I will give it the good ol' college try. Stay cool my friends!
Old 07-20-2016, 05:23 PM   #9
B and B's Avatar
Sending helping vibes your way Hector. DYB. Cub Scout Motto. Do Your Best
B and B
Old 07-20-2016, 06:26 PM   #10
Double Flooring
Thanks, B and B. A friend of mine with carpentry skills is helping me build a wood frame upon which to lay a 3/4" OSB custom cut sheet. An indoor/outdoor rug will be glued and stapled on top. A beveled piece will minimize the outer floor lips. All is good.
flooring
