Old 06-26-2015, 12:13 PM   #11
Originally Posted by Maverick2902 View Post
Agree - it's holding good now. Will check after this weekend to see how it really did. Don't like to find my bottle of scotch on the floor
I believe you bottle of scotch will be safe.
Ken Y is offline   Reply With Quote
Old 06-26-2015, 12:34 PM   #12
lckeehne's Avatar
I had several drawers in kitchen and bedroom come flying out on the 6th wheel. The bracket actually broke the wooden vertical member.
I had new latches installed and no problem now.
lckeehne is offline   Reply With Quote
Old 06-26-2015, 12:35 PM   #13
frozen's Avatar
Doors/drawers that open on the road are especially troublesome when they can get hooked by a slide as it's extended. I tore a pantry door off the hinges with the slide. A friend tore off a door pull and the trim on the slide. My wife found "surface bolts" at Home Depot. They look good and are relatively easy to install. About $5 each.
frozen is offline   Reply With Quote
Old 06-26-2015, 12:36 PM   #14
Maverick2902's Avatar
Child Safety latches are the best secondary containment
Maverick2902 is offline   Reply With Quote
Old 06-26-2015, 12:36 PM   #15
mike.t's Avatar
I installed the top one. Works fine.
rv drawer latch | eBay
2017 Freelander 26RS
2013 Ram 1500 4X4 Hemi
1998 Jeep Wrangler
2014 Dodge Durango
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 06-26-2015, 01:00 PM   #16
Herk7769's Avatar
Bungee Cords....
ID:	81196   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 06-26-2015, 01:49 PM   #17
Scotch should be stored in stomach!!!!!.J
Jim in Halifax is offline   Reply With Quote
Old 06-26-2015, 02:01 PM   #18
karrun's Avatar
I just worked on all of mine. If you have drawer catches like the one pictured, you will need to open up the triangle shaped section for a better grip or move it to where it's going in and being gripped by the rollers. I inserted a flat head screw driver and opened them up. Two of my drawers were off by 2 inches not catching at all.... Attachment 81153
Thanks for this! This is absolutely the only issue we've had with our new 2016 Roo and its been driving me nuts. Wasn't going to drive an hour to the dealer and have the Roo out of commission for who knows how long just for this. I was going to wait for the end of camping season to bring it back. Now maybe I can fix it myself.
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
karrun is offline   Reply With Quote
Old 06-26-2015, 02:06 PM   #19
We had the drawer under the stove come open on the trip home in April.
finally I saw the problem that was not easy to see. Both of the drawer guides that are on the cabinet had a broken piece that held the drawer lock and when you opened we had to lift up and pull out. That was an easy cheap fix.
labarn
labarn is offline   Reply With Quote
Old 06-26-2015, 03:41 PM   #20
Thanks, I'll look at them this weekend. Sorry, they are the smaller kitchen cabinets for towels and silverware. I need them to stay shut. The main culprit is close to my ATV's, but the Harley is going in there next trip and that drawer will be sitting on the side of the highway if it opens and dings up that paint.
That one looks like it's installed slightly crooked, so maybe it just needs readjusting. I have a couple others that open too, on the other side under the TV. They are all the smaller drawers.
slapshot12 is offline   Reply With Quote
