Old 08-13-2013, 12:14 PM   #21
Originally Posted by Lynkage View Post
OK!
So I removed the center marker light and found this will be a great way to run the wire.
More pics........
Are you sure that hole is big enough? ;-)
Old 08-13-2013, 01:00 PM   #22
Lynkage's Avatar
Just barely!!
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 08-13-2013, 01:46 PM   #23
Lynkage's Avatar
Talking Done
All done
Name:	from ground.jpg
ID:	37574   Click image for larger version
ID:	37575   Click image for larger version
ID:	37576   Click image for larger version
Name:	Inside through rear wall.jpg
Shane & Antoinette
Old 08-13-2013, 01:50 PM   #24
JoeMazz's Avatar
Where did you go with the wires once in the cabinets? I have a vent hole already in place that goes from the rear cabinets out above the rear window.
2015 Jayco Precept 35UP
JoeMazz is offline   Reply With Quote
Old 08-13-2013, 02:06 PM   #25
Lynkage's Avatar
My rear cabinets go all around the rear window and the wire I ran from the front is coming through the floor in the bottom cabinet behind the converter.
PS... I had to take 2 pics as they were to dark as one and I only have auto flash.
Hope this helps someone to install one in the future.
ID:	37580   Click image for larger version
Name:	under window.jpg
Shane & Antoinette
Old 08-13-2013, 02:12 PM   #26
Fulltime family RVer
5200 can never be removed. I would suggest something less permanent.
Heh, too true. In my kayak building days, the saying went something like:
  • 3M 3200 is going to be there forever
  • 3M 4200 is permanent
  • 3M 5200 is if you want to hate yourself later
exterior, back up camera
