Old 08-12-2013, 05:59 PM   #1
Lynkage's Avatar
Drilling through the exterior for a backup camera
What is the best way to go about mounting a wired backup camera and running the wire through the exterior and get a good seal so I do not experience a delamination problem?
I have already run a coax from the kingpin to the rear inside the cabinets on the back wall so the inside wiring is almost done no problem there.
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 08-12-2013, 07:34 PM   #2
Lynkage's Avatar
A few pics of the wire run.
ID:	37527   Click image for larger version
Name:	Front hatch camera wire.jpg
ID:	37528   Click image for larger version
Name:	Conduit down frame.jpg
ID:	37529   Click image for larger version
Name:	cable entrance to converter box.jpg
Shane & Antoinette
Old 08-12-2013, 08:07 PM   #3
Lynkage's Avatar
One more of the inspector Turbo!!
Name:	Front reinforcement.jpg
Shane & Antoinette
Old 08-12-2013, 08:22 PM   #4
Owner/Operator
RodeoGeorge's Avatar
Yes, that does look a lot like Turbo!
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
https://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 08-13-2013, 07:22 AM   #5
Lynkage's Avatar
Nobody has drilled through their fiberglass exterior?
Shane & Antoinette
Old 08-13-2013, 07:34 AM   #6
TURBS's Avatar
He's on it!
Old 08-13-2013, 07:35 AM   #7
TURBS's Avatar
I have not but slow and easy and plenty of sealer!
A dremel and a deburring bit I believe would be better than a twist bit.
Old 08-13-2013, 07:36 AM   #8
JoeMazz's Avatar
I'm curious myself. Getting ready to do this on my 8282ws. Where are you mounting the camera? I have a spare tire on the rear bumper, as well as a large rear window, so I'm going to have to mount it high.
2015 Jayco Precept 35UP
JoeMazz is offline   Reply With Quote
Old 08-13-2013, 07:41 AM   #9
Lynkage's Avatar
I guess my main question would be, Should I sand/scotchbrite the area and then mount the bracket with sealant so it sticks better?
I am going to cover the big hole for the wire as much as possible with the mounting bracket as well as put the bracket above the hole.
I will get a picture of what I think I will do.
Shane & Antoinette
Old 08-13-2013, 07:42 AM   #10
Lynkage's Avatar
I have a large window as well. I want it just below the middle marker light on the back.
Shane & Antoinette
Old 08-13-2013, 07:54 AM   #11
Herk7769's Avatar
To avoid cracking the exterior, use a small pilot hole and step up slowly to the size bit you need. Seal wire filled hole completely with "Silaprene" sealant.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 08-13-2013, 08:23 AM   #12
One more important thing (learned from boat fiberglass): After drilling the hole, use a countersink bit to angle the edges. If you don't, you'll start a crack in the fiberglass from the hole outward.
Old 08-13-2013, 09:12 AM   #13
gooiebob's Avatar
My first camera install on our other trailer that burned was easier than out new one.
I mounted the camera above the middle marker and used the stick on cable hide system from Lowes. Held on great and matched the exterior white. Couldn't hardly see it if you weren't looking.
On our new 2703 I had the ladder mounted in the middle and attached the camera to the top of the ladder just beneath the marker light. Ran the wires behind the ladder rail and ran the wires between the coroplast and the floor. Would have used the cable hide system but couldn't find any black to match the rear end corner molding.
Bob
2019 Della Terra 29k2s
2014 Toyota Tundra 5.7
gooiebob is offline   Reply With Quote
Old 08-13-2013, 09:13 AM   #14
Lynkage's Avatar
Thanks Guys!!
I was planning on using my uni-bit and it will chamfer the edge. I need a 1/2" hole for the wire to go through.
Let me go take some pics............
Shane & Antoinette
Old 08-13-2013, 09:20 AM   #15
I would go to a boat store and get some 3M 5200 to seal the hole. We use it in marine applications all the time, even below the water line.....
rlreed is offline   Reply With Quote
Old 08-13-2013, 10:03 AM   #16
Lynkage's Avatar
More pics
Here are some pics of the mounting location.
A thought occurred to me that I may be able to go through the bottom of the marker light and into the trailer that way. I will have a look in a bit.
ID:	37555   Click image for larger version
ID:	37556   Click image for larger version
Shane & Antoinette
Old 08-13-2013, 10:03 AM   #17
5200 can never be removed. I would suggest something less permanent.
Old 08-13-2013, 10:34 AM   #18
AquaMan's Avatar
I've actually done more than just drill through the outside. Piece of cake. Drill it like its wood. Factory told me to simply use jigsaw with normal blade. That's how they do it.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 08-13-2013, 11:11 AM   #19
Lynkage's Avatar
Thanks TT!!
Shane & Antoinette
Old 08-13-2013, 11:46 AM   #20
Lynkage's Avatar
OK!
So I removed the center marker light and found this will be a great way to run the wire.
More pics........
Name:	marker entry.jpg
ID:	37567   Click image for larger version
Name:	Slot for wire.jpg
ID:	37568   Click image for larger version
Name:	wire through marker.jpg
Shane & Antoinette
exterior, back up camera
