Old 03-30-2016, 01:16 PM   #1
Driving lights or fog lights
Has anyone mounted extra lights to the front of there ford class c looking for place and type to buy
retired on a mountain is offline   Reply With Quote
Old 03-31-2016, 12:05 PM   #2
Wandering's Avatar
Following. How did you hook up too?
Forester 2451s
Forester 2451s
Wandering is offline   Reply With Quote
Old 04-01-2016, 09:37 PM   #3
World Wide Wanderer
wahoonc's Avatar
Haven't but I will be using the Hella 550's. I have used them on other vehicles over the years with good results.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is online now   Reply With Quote
Old 08-13-2016, 11:17 PM   #4
No-Fish's Avatar
mounted a set of 4.5 in LED lights inside the bumper, and due to the low current draw w/ LED 's I hooked mine to the lt park light hot wire,
No-Fish is offline   Reply With Quote
Old 08-15-2016, 02:39 PM   #5
LED are the way to go these days.
Check out Amazon for frequent deals on LED lights.
I bought a set awhile back with the plan to mount them under the bumper of my truck to help light up on backing up... they still are in my garage on the shelf though
mkosu04 is offline   Reply With Quote
Old 10-18-2016, 09:00 PM   #6
seidcon's Avatar
fog lights/led
My 2015 GMC 2500HD has projection headlights and create a huge blind spot on either side of the vehicle.
I replaced the stock fog light bulbs with high output LED bulbs and used reflective tape on the inside face of the black bezel. This reflects a lot of light to the sides.
I also removed the grill, mounted an 18" wide LED light bar then re-installed the grill. I added a relay between the light bar and the battery terminal and used the fog lamp hot lead as the relay on/off. I pointed the light slightly down so the beams mirrored the low beam light pattern.
On those dark nights when you're away from the city lights, it makes all the difference in the world.
seidcon is offline   Reply With Quote
Old 10-26-2016, 08:17 PM   #7
Get HIDs, 20$ on ebay for a set. 4300k in color. Best upgrade you can do to your truck. After you will not need driving lights nor fog lights.
Kuba is offline   Reply With Quote
Old 10-31-2016, 04:40 PM   #8
i installed a license plate bracket/ light bracket from vision x. I have a couple driving lights on there now, but will probably switch to a 18" LED light bar.
akcampr is offline   Reply With Quote
Old 10-31-2016, 04:53 PM   #9
Nothing worse than an oncoming person with those lights that don't have the sense to dim / turn them off.
You can get a ticket for that if the opposing driver is a cop....
That OEM fog light thing irritates me to no end. It ain't foggy....duh...
SidecarFlip is offline   Reply With Quote
Old 11-02-2016, 12:57 AM   #10
Beards79's Avatar
I added a 20" LED single row light bar inside the bumper and mainly use it when we go up the mountain late at night to some friends house, it is however tied into the high beam side of the headlights and also has a switch on the dash! Works perfect.
Take Vacations.. Go as many places as you can!
You can always make money..
But you can't always make memories!
Beards79 is offline   Reply With Quote
light
