Old 06-28-2015, 12:03 PM   #11
Grumpy - That is a terrific idea for manual awnings. The awnings on both our camper and our house are manual and we have had the same issue with the one on our house. The problem returns after the part wears down again. This can be adapted so that one side can be left down for drainage if the weather report is not favorable. Going to show this to DH tonight. I'm sure he'll want to thank you, eventually.
2007 Rockwood Roo 232
2002 Chev Silverado 2500 HD Crew Cab
Me and DH (aka the Bearded Guy) and as many kids and grandkids as are available at any given time.
The only thing necessary for the triumph of evil is for good men to do nothing. - Edmund Burke
KateE is offline   Reply With Quote
Old 06-29-2015, 09:18 AM   #12
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by Maris View Post
Thanks. We have the same trailer as you. You mean that the auto awning will dump the water if it accumulates and then go back to its original position?
Yes, exactly. Scared the snot out of me the first time it happened.
Water begins to collect on the downhill side of the awning until its weight overcomes the pressure of the tensioning piston. That end of the awning collapses (slides down the support to its lowest point) by itself and dumps all the water. Once the weight is gone, the piston returns the awning to its original position. Of course you trot on over and pull that side down a bit and tighten the knob to hold it down so the rain no longer accumulates. It's a great fail-safe mechanism. So don't tighten those knobs unless you use them to lower one end of the awning prior to wet weather.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
awning, modifications
