Old 06-27-2015, 07:38 AM   #1
grumpy0374's Avatar
Easy Awning Mod / Lock
On our last trip out, during a light breeze, one of the awning knobs that tightens the support came loose (found the captive nut in knob had stripped) and that side of the awning partially collapsed.
On returning home, had a few of these captive wire pin locks and used them. They're 1/4 inch x 2 inch. Drilled a 5/16 inch hole through the extended support, behind the knob. Hole goes thru both parts of the tubing.
Now, when setting up, after support is extended, Pin goes in, locks, and no more worry.
Grumpy
ID:	81263   Click image for larger version
ID:	81264   Click image for larger version
grumpy0374 is offline   Reply With Quote
Old 06-27-2015, 07:53 AM   #2
peterbilt's Avatar
real nice
peterbilt is offline   Reply With Quote
Old 06-27-2015, 10:24 AM   #3
Why not replace the knob? What you did looks good but, now you cannot adjust your awning for rain drainage.
propbndr is offline   Reply With Quote
Old 06-27-2015, 10:34 AM   #4
grumpy0374's Avatar
I did replace the knob, actually both of them. Awning will still come down enough on one side (rear) for water drainage (front can't come down due to slide out). However, if I do have to lower it a lot, simple matter to drill an extra hole lower down and insert the pin.
Grumpy
Old 06-27-2015, 11:46 AM   #5
Maris's Avatar
Looks like a great idea. We'll keep that in mind. The awning on our Shamrock 23ss wasn't automatic & seemed sturdier than the one on our Rockwood 2604. We may need this mod in the future.
Maris is offline   Reply With Quote
Old 06-28-2015, 09:30 AM   #6
AKA: 'tiredTeacher
awellis3's Avatar
Keep in mind our awnings have an "automatic dump feature." If you forget to lower one end of the awning before a rain and the awning collects water, the support will give way, dump the awning then return to its extended position.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 06-28-2015, 09:44 AM   #7
grumpy0374's Avatar
I don't know if this would work on a power/electric awning. Mine is a manual extend/retract, and it does exactly what I needed it to do, and I can still lower one side to let water run off.
Not sure how the power awnings are set up or what safety features they have.
Grumpy
Old 06-28-2015, 10:56 AM   #8
Maris's Avatar
Thanks. We have the same trailer as you. You mean that the auto awning will dump the water if it accumulates and then go back to its original position?
Maris
Old 06-28-2015, 11:13 AM   #9
Grumpy
This is the Info that should have been incorporated in Post #1! Grumpys awning is a (Manual Type)! Don't drill and pin if your unit has (Elect Type)!! Youroo!!
Old 06-28-2015, 11:32 AM   #10
grumpy0374's Avatar
youroo, your right and I do apologize. Thought that pics of the awning supports with the knobs would suffice.
To all, my awning is a MANUAL type where the supports are a tube in a tube sliding type where this pin would work .
Again, a thousand apologizes.
Grumpy
awning, modifications
