Old 02-23-2014, 04:22 PM   #1
BigTJohn's Avatar
Easy slides in storage bay
Name:	ImageUploadedByForest River Forums1393192990.050202.jpg
ID:	46679Click image for larger version
Name:	ImageUploadedByForest River Forums1393193007.599254.jpg
1/2" plywood for all pieces, hardwood "tip preventers" and 1.5" alum angle stop at back to prevent over retracting the slide too far. Click image for larger version
Name:	ImageUploadedByForest River Forums1393193227.947338.jpg
ID:	46681 the PVC is a "lock" which runs the full length of the bigger slide that is a full width slide, can be pulled from either side with brass handle. Rubbermaid totes, one tall in the center and two stacked on both outboard ends keeps stuff from rolling around.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 02-27-2014, 04:10 PM   #2
BigTJohn's Avatar
More PIX of slides
Name:	Slide supports.jpg
ID:	46927 Rails for the shelf to side on, full bay width
Name:	Slide install 4.jpg
ID:	46928 Port side view, PVC is the slide lock
Name:	Slide Install 3.jpg
ID:	46929 Stbd view shows ladder on shelf fwd of slide
Name:	Slide install 1.jpg
ID:	46930 Slide fully extended with support to ground (adj)
Name:	Slide install 5.jpg
ID:	46931 Close view of ladder, slide, lock
This works pretty well for most things I carry. Also allows for good management of items and keeps the storage bay neat.
Brenda and John
slide, storage, slide out
