Old 06-19-2018, 07:22 PM   #21
Originally Posted by 1948ncroy View Post
.....The fan is definitely worth the $20+.....
Can you send a link?
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
chaps2018 is offline   Reply With Quote
Old 06-19-2018, 07:46 PM   #22
Originally Posted by garbonz View Post
Look at ARPRV...high flow quiet squirrel cage fan...much more CFM than the computer jobs.
Thanks for the tip. I will switch to a centrifugal blower. Mainly for CFM/noise but also it looks like it will be more effective at blowing air directly through the vent outside.
Old 08-31-2018, 12:40 AM   #23
MacGumbo's Avatar
Originally Posted by fairpilot View Post
Ok, i see where it makes sense now not to pull air down, so i am going with 80 cfm computer case fan blowing up, my fridge is Dometic and is not in the slide we have a rear kitchen fridge and it will not get below about 42-44 during day, hits about 35 after all night we will see if this helps Thanks you for all the suggestions
Just checking. How have you solved your problem and did it work?
2020 Grand Design Reflection 240 RL
2006 F350 Lariat Crew Cab Super Duty 6.0 diesel 4X4
MacGumbo is offline   Reply With Quote
Old 08-31-2018, 06:26 AM   #24
Fridge is hit or miss. Seems to work much better on gas. Will cool down to 35-38 overnight but hard to get that during day. Freezer goes to -5 , it seems to do well. I usually go buy some dry ice and set in fridge, keeps it really cold about 3 days.
fairpilot is offline   Reply With Quote
Old 08-31-2018, 09:27 AM   #25
Gas SHOULD do better. On a Dometic 2562, the gas burner puts out 1500 BTUs/hr, while the electric element is 325 watts, or 1108 BTUs/hr. So the gas puts out 35% more heat than the electric element. Efficiency is proportional to the highest and lowest temperature in the cycle.
2011 Traverse LT, 3.6L, FWD
cooling, electric, fan, fridge
