Old 11-23-2015, 06:53 PM   #1
Rmk2001800's Avatar
Electrical guys....
Ok I have a park model with a 50amp service- I want to add a washer and drier- the drier is a residential 220
What are my options to hook this up.
My thought was split the 50amp service into a regular panel I would have to add then pull 220 for the drier and pull 2 50 amp single pulls to the service panel in the park model.
Thoughts?
Rmk2001800 is offline   Reply With Quote
Old 11-23-2015, 07:10 PM   #2
Why not just get a propane dryer?
AGFazio is offline   Reply With Quote
Old 11-23-2015, 07:20 PM   #3
Rmk2001800's Avatar
Don't have access to it easily
Old 11-23-2015, 07:48 PM   #4
Depends where you can locate your new panel, if you can disconnect the incoming wiring and move it to the new panel, then you could run new wire to the incoming connection. I would use a panel with big enough lugs on the input so you put both the incoming wires as well as the wire going to park model panel under the same lugs. There is no reason to install additional 50 amp breakers for the trailer, just one 30 amp double pole for the dryer. You will have to watch what you turn on while the dryer is running.
caesar101 is offline   Reply With Quote
Old 11-23-2015, 07:59 PM   #5
Rmk2001800's Avatar
The cord to the park model has 15' extra slack so I was just going to cut it in half- but sounds like I can just put both wires in each lug.
What box do you recommend to supply a 30 amp drier and 20amp washer?
Old 11-23-2015, 08:10 PM   #6
Something like this
Square D Homeline 100 Amp 6-Space 12-Circuit Indoor Surface Mount Main Lug Load Center with Cover-HOM612L100SCP - The Home Depot
Old 11-23-2015, 08:27 PM   #7
Rmk2001800's Avatar
Where do the hide the amp main breaker? Under the cover? Or does it use 2 of the slots?
Old 11-24-2015, 09:55 AM   #8
Head Rambler
Which model power panel do you now have?
You may be able to run a cable from the sub feeds in the panel to a 4 circuit breaker panel close to the existing panel and then run wiring from there to the washer and dryer plugs.
Gotta go campin!
Old 11-24-2015, 09:57 AM   #9
You don't need a main breaker for anything. The new panel is protected by the campground breaker and the trailer does not see any change as the wire still comes from the campground breaker to the main panel it just has a tap off it for the new panel.
electric, electrical
