Old 10-13-2015, 02:11 PM   #1
Electronics question?
We have our 2015 Salem 31QBTS in a campground that doesn't have very good radio reception The factory stereo seems to lose signal more and more as we turn on lights or any other DC powered devices I think the factory power converter isn't strong enough to handle the load is there another way I can power the factory stereo/DVD player other than with the built in inverter
I tried a signal booster but it's DC also and hooked to the same power supply so it didn't make a difference
Any suggestions???
Rgsa8892 is offline   Reply With Quote
Old 10-13-2015, 02:40 PM   #2
clr
I would look behind the unit and ensure that the antenna is connected properly and tightly and is separate from the nest of other wires behind the stereo first. I really do not think the dc power is the issue here, the stereo uses very little power, but check the dc power cable connections also when you have the stereo out.
clr is offline   Reply With Quote
Old 10-13-2015, 02:44 PM   #3
I checked all that when I put the signal booster in but when I turn the radio on it's fine as you turn a light on the signal starts to fade away turn another light on and it fades even further that's why I'm thinking its the power
Old 10-13-2015, 02:52 PM   #4
Boss Ox & Drovergirl
oxcamper's Avatar
Are the connections to the power inverter from the stereo correct and not reversed?
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 10-13-2015, 03:03 PM   #5
Yes I'm familiar with wiring stereos
Old 10-13-2015, 04:26 PM   #6
Jim Schings's Avatar
I am an EE with lots of experience with consumer electronics. I have to say, that your symptoms, if I understand them correctly are VERY strange. In the case of low power, the audio would be the first symptom. (distortion or lower volume). Adding a lamp etc to the load, would hardly make any difference in station reception. It would probably require a drop of 4 volts or more for it to bother the RF reception. If that were the case, you would certainly notice a drop in the lamp(s) brilliance. In any case, the first thing would be to check the voltage to the unit. With no other loads and then keep measuring as you add loads. As a matter of interest, does your FM and AM do the same thing? Any other devices that use this stero? CD's etc. I would try that.
Jim and Katy
w/ Shelby and Sealy (Bernese Mountain Dog and a Nice Mut)
FR3
HAM CALLSIGN - AI4SR
EE, IBMer, Race Car Builder, now Retired.
Jim Schings is offline   Reply With Quote
Old 10-13-2015, 04:46 PM   #7
I go RV'ing not Camping
jgourlie's Avatar
What kind of light bulbs do you have??? Are they LED??
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 10-13-2015, 04:48 PM   #8
2012 Solera
Several forum members have reported that some LED lights have internal drive circuitry that emits sufficient RF to interfere with radio and/or TV reception.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 10-13-2015, 04:55 PM   #9
Yes, it COULD be RF issues with LED drivers, however the OP said with ANY DC powered loads.
Jim and Katy
FR3
Old 10-13-2015, 08:47 PM   #10
leefl's Avatar
Sounds like perhaps the inverter itself (if the stereo is 110v powered) or the 12v power supply (which I'm guessing is what you really mean) may be outputting a lot of electrical noise (especially when under heavier load) which is interfering with the radio signal. You could try putting an RF choke on the supply to the stereo.
It may even be that there's a faulty capacitor on the 12v output stage of the psu causing the extra noise.
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
